Hot Water Slow Fill - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2014, 08:44 PM   #16
Rewards Points: 6,652
Originally Posted by thefixer56 View Post
You have a problem with your hot water pressure. Cold water comes in fine, you disconnect the cold water hose and connect hot water to same inlet, select cold water and hot water trickles in. Nothing wrong with your washer. That's an old (pre 1985) belt drive model, nice machine!
They have already stated that the problem is with the fill valve, not water pressure.
Old 02-26-2014, 10:12 PM   #17
Rewards Points: 137
They??? They are wrong. It ain't rocket science. With cold water hose connected to cold inlet valve, energize valve solenoid, water comes in fine. Disconnect cold water hose, connect hot water hose to same inlet valve, energize same valve solenoid, water trickles in. What has changed? The water supply hose. Go ahead and change the valve assembly if you want but get the proper valve for your machine. They are not generic one model fits all. Part number is 358277. Buy from repairclinic.com and you may return it when you find out it doesn't fix the problem.
thefixer56 is offline   Reply With Quote
Old 03-11-2014, 03:44 PM   #18
Rewards Points: 150
and the winner is.......? The fixer! new valve same old same old. A little better but as water get hotter flow slows down. I noticed when flushing out hoses and valve fill valves , to make sure there wasn't any debris in them that there was a slight difference between the cold and hot streams, hot seemed a little weaker. Went down cellar and looked, there are 3 stop and waste valves in the line for some reason.maybe it's time to take 2 of them out. ..... put it on the someday to do listthanks everyone.n I think I answered my own question in the original post as I re-read it.
hpyjack2013 is offline   Reply With Quote
Mysterious Yellow How Water in Tub only heyjoe91 Plumbing 11 10-22-2013 04:23 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 02:37 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
