Hooking Up A Propane Stove - Appliances - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Canarywood1
  • 1 Post By Drachenfire
  • 1 Post By Yodaman
Old 04-09-2019, 01:42 PM   #1
Rewards Points: 2
hooking up a propane stove
I'm looking to hook up a propane stove/oven at our camp. I need to know what size and type of fittings, copper tubing, valves, regulator, etc. to go from the back of the unit, down through the floor, through the exterior wall, and into a propane tank outside.
brian225 is offline   Reply With Quote
Old 04-09-2019, 05:36 PM   #2
Rewards Points: 922
Re: hooking up a propane stove
Call who ever owns the tank .
Yodaman likes this.
Canarywood1 is offline   Reply With Quote
Old 04-09-2019, 05:57 PM   #3
Big Dog
Drachenfire's Avatar
Rewards Points: 3,850
If you have never done gas lines before, I strongly suggest you call in a professional.
In most situations, LP lines are 3/8" copper and the ends need to be flared within the fittings that screw into the mating fittings and regulator. Flaring copper requires a special tool and some practice to get the flare right.
The last thing you want is a gas leak especially inside the home.
supers05 likes this.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 04-09-2019, 06:47 PM   #4
Property Mgt/Maint
Rewards Points: 6,232
And especially with propane. It operates at higher PSI than NG, and it is also heavier than air, so it can settle undetected in basements.
[political signature removed]
Yodaman is offline   Reply With Quote
Heat Circulation - Propane Stove gdoucette HVAC 5 11-19-2013 04:52 PM
Propane Line for 30" Stove chipraynor Plumbing 5 09-18-2012 09:43 PM
install gas stove to existing propane line Mark86 Plumbing 9 08-28-2012 11:20 PM
Propane cook stove A. Lobb Appliances 3 02-06-2012 01:22 AM
Hooking up a non-equipped pellet stove to a home thermostat bobbyc HVAC 4 09-25-2009 02:24 PM
