Help Identifying Bulb For Water/ice Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 10-07-2019, 01:15 PM   #1
Rewards Points: 120
Help identifying bulb for water/ice dispenser
Need help identifying the bulb I need for the water/ice dispenser on a fridge that came with the house we just purchased. Tried a couple bulbs but couldn't get any to screw it, then I actually looked at the base and it looks weird. Is the base busted or this for some kind of bulb that doesn't screw in?
Help identifying bulb for water/ice dispenser-bulb.jpg
jmg32 is offline   Reply With Quote
Old 10-07-2019, 01:49 PM   #2
Oso954's Avatar
Rewards Points: 914
Re: Help identifying bulb for water/ice dispenser
It would have helped if you said who made the fridge, so we would not have to guess.
If itís a GE, try this.
https://www.amazon.com/General-Elect...TCJ1AQZWGK4CJH
If you can find the model number of that fridge, you can double check the bulb by entering the model # on the Amazon page.
Oso954 is online now   Reply With Quote
Old 10-07-2019, 01:53 PM   #3
Rewards Points: 120
It is a GE GSE25ESHB SS
Old 10-07-2019, 01:56 PM   #4
Rewards Points: 120
Thanks. Hadn't noticed that function on Amazon to search for the model number.
I'm guessing the socket on our dispenser is busted b/c I don't see any grooves for screwing the light bulb in.
Old 10-07-2019, 02:03 PM   #5
Oso954's Avatar
Rewards Points: 914
It should fit.
Here is a listing of door parts for that fridge.
https://www.appliancepartspros.com/f...e25eshbss.html
The bulb is number 56, the socket is 61.
Note the PART # WR02X12208 Is also known as AP3884244
The Following User Says Thank You to Oso954 For This Useful Post:
jmg32 (10-07-2019)
Old 10-07-2019, 02:11 PM   #6
Rewards Points: 120
Thanks. Ordered on Amazon!
Old 10-07-2019, 05:56 PM   #7
Rewards Points: 680
Isn't that just a 5 watt candelabra night-light bulb?
LawnGuyLandSparky is offline   Reply With Quote
Old 10-08-2019, 06:00 PM   #8
Oso954's Avatar
Rewards Points: 914
Candelabra base, but 12V 6watt incandescent.
Old 10-08-2019, 09:43 PM   #9
Rewards Points: 2,512
Get a led equivalent and you’ll never replace it again
bob22 is offline   Reply With Quote
