Grill Ignitor - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 06-10-2018, 10:36 PM   #1
Rewards Points: 996
grill ignitor
any tips for diognosing my 4 y/o ignitor ? i did change the battery, that is as far as i got.
thanx
Fix'n it is offline   Reply With Quote
Old 06-11-2018, 06:35 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 640
Re: grill ignitor
Trash can fall on the electrode and cause it not to work, so check that out as well. If you don't see a spark it is possible the whole unit has gone south and needs replacing. Replacements are readily available at box stores and online.
lenaitch likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-11-2018, 08:53 AM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 644
Re: grill ignitor
^^. You could try bending the shroud in a bit to shorten the distance to the electrode. As well, if the shroud is really rusted it may impair the ability of the electrode to ground out. It's a pretty low powered device.
_________________________________________
Sic Itur at Astra
lenaitch is online now   Reply With Quote
Old 06-11-2018, 10:22 PM   #4
Rewards Points: 996
Re: grill ignitor
thanx guys
it has 4 electrodes, 2 on the sdie we always use, and 2 on the side that we almost never use.
i will wire brush them and see what happens. something is telling me its a dirty/rusted connection.
outdoor built-in gas grill question tarheelblue Appliances 1 06-07-2015 10:38 PM
Mouse in Grill NickTheGreat Pest Control 3 09-05-2014 06:34 PM
Help with Nat. Gas Line for Grill albertgarrido Plumbing 7 06-29-2010 02:57 PM
Weathermaker 9200 Ignitor fails to light Atomic HVAC 5 03-22-2010 12:59 PM
Painting A/C Fan Grill fritzycat1 Painting 3 09-09-2009 05:50 PM
