GE Side By Side Freezer Is Icing Up. - Appliances - DIY Chatroom Home Improvement Forum
Old 08-30-2014, 11:13 PM   #1
Rewards Points: 16
GE side by side freezer is icing up.
I took out the ice bin and it's defrosting now, but it was completely almost iced over. Anything wrong or perhaps just needs to be defrosted?
2leftthumbz is offline   Reply With Quote
Old 08-30-2014, 11:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
May have inbound water deflecting somehow, freezing and fowling up the mechanisms. Check the flow tube to see that it is clear of ice or any obstacle. Thawing and defrosting will likely clear the issue and you'll never know what the problem was.
PS; you could use a hair dryer to speed things along a little.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
2leftthumbz (08-30-2014)
Old 08-31-2014, 08:54 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,716
you have a water leak there. Like Bud mentioned most likely from the fill tube for icemaker, also sometimes at the point where the fill tube goes into the icemaker will build up ice and spray water all over
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-31-2014, 09:41 AM   #4
Rewards Points: 16
Ok. Thank you. I won't be able to look at it until tonight. So I would just need a new fill tube?
Old 08-31-2014, 02:54 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Maybe not, may just be a freak happening. Thaw things out and start over and see what happens. Don't be too quick to begin replacing parts just yet.
XXX
Old 08-31-2014, 09:24 PM   #6
#1 HAWKEYE FAN
no reason to replace it, just thaw it out.
Ge side by side making noise mj12 Appliances 0 07-09-2013 09:58 PM
coaxil side by side with cat5 telephone wire DiegoJames Electrical 3 06-11-2013 06:53 PM
GE side by side not cooling (pics)..HELP! Exjay Appliances 5 06-10-2013 07:27 PM
Maytag Side by side dannykapp Appliances 25 02-27-2011 10:25 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
