GE Fridge Won’t Get Cold Enough - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 01-02-2019, 02:26 PM   #16
Rewards Points: 60
Re: GE fridge won’t get cold enough
DoomsDave,
If your freezer coils (at the back of the freezer) aren't iced over (you might need to remove the rear interior panel to check), then your damper is probably stuck closed.
When the fridge is too warm, the dampers opens and the fan kicks on to blow cold air from the freezer into the refrigerator. A little motor controls the opening and closing of the damper and yours might either be frozen shut, jammed, or broken.
-Mike
DoomsDave likes this.
Mr.Vile is offline   Reply With Quote
The Following User Says Thank You to Mr.Vile For This Useful Post:
DoomsDave (01-03-2019)
Frigidaire LGHB2867PF2, fridge compartment warm, freezer cold seb2441 Appliances 0 10-07-2018 10:24 AM
fridge side not cold enough. kenmore coldspot model 106.57713701 Yessy Appliances 1 06-11-2018 05:28 PM
Furnace cold air return air noice geopass HVAC 16 03-12-2018 10:22 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 03:39 PM
