Gas Dryer Not Drying Like Normal - Appliances - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By Dave Sal
  • 1 Post By de-nagorg
Old 05-31-2018, 12:37 PM   #1
Dave Sal's Avatar
Rewards Points: 262
gas dryer not drying like normal
Hey guys,
Last week I posted a thread about changing a drum wheel on my Kenmore HE4 gas dryer. It was one on the rear and I removed the rear panel and was able to replace it without having to remove the drum itself.
Since then though, the dryer doesn't seem to be working like it used to. I just removed the front lower panel and turned it on and noticed that the burner ignites for about 13 seconds, then it shuts off for about a minute, and then it ignites again for the same 13 seconds. Is this normal behavior for a gas dryer, or is it shutting down too quickly? I've never had the need to observe how long the burners should be on so any comments are appreciated.
Dave Sal is offline   Reply With Quote
Old 05-31-2018, 12:56 PM   #2
JUSTA MEMBER
Rewards Points: 1,124
Re: gas dryer not drying like normal
Did you mess with the exhaust venting, Cleaned the venting lately, a nearly plugged exhaust severely delays the time it takes to dry the clothing.
Is there a filter screen that needs care, did you reattach the vent hose,
A gas expert might be along with the answer to your question, Sorry that I don't know.
ED
de-nagorg is online now   Reply With Quote
Old 05-31-2018, 02:55 PM   #3
Dave Sal's Avatar
Rewards Points: 262
Actually I did clean the exhaust vent a bit. I didn't take the whole thing down as I did that last year and it wasn't as bad this year. The filter screen is cleaned after each use and I put everything back the way it was. Thanks for the reply.
Old 05-31-2018, 11:43 PM   #4
JUSTA MEMBER
I thought of another thing.
In the springtime, Young Cocks ( male birds), start thinking of romance, and build a nest to bring the new bride home to, often this nest is built in an accessible dryer exhaust vent.
Have you looked in the outside vent, to see if the mesh has been pushed away, and a nest is in there?
ED
Old 06-01-2018, 11:04 AM   #5
Dave Sal's Avatar
Rewards Points: 262
Yesterday after reading your comments I decided to move the dryer and clean out the vent. The inside of the dryer wasn't too bad as I had cleaned it last year but the vent definitely needed cleaning as it was worse than I thought. I didn't see any blockages but got quite a bit of lint out of it. I then went outside and checked the exhaust vent and while there were no bird nests or anything, it was also a bit linty. Cleaned it out as well and later on ran a load of towels in the dryer. This time they were dry when the cycle finished so I'm assuming your diagnosis was correct. Appreciate the replies.
SeniorSitizen and de-nagorg like this.
Old 06-01-2018, 11:24 AM   #6
JUSTA MEMBER
YEA, I like it when a simple idea was what was needed.
So a lesson to everyone, a cursory cleaning of the area , won't be " good enuf", Thoroughly clean the entire dryer venting system.
Save energy, MONEY, and aggravation.
I am glad to help.
ED
SeniorSitizen likes this.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 02:10 PM
Dryer venting consideration miamicuse General DIY Discussions 3 02-04-2014 12:19 PM
Dryer Vent Problems - Small Space moose8721 Appliances 5 10-30-2013 11:20 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
dryer not drying determined1 Appliances 5 04-07-2009 10:09 PM
