Front Load Washer Water Level Switch - Appliances - DIY Chatroom Home Improvement Forum
Old 04-09-2019, 08:08 AM   #1
Rewards Points: 1,475
I'm looking to buy a used front load washer, and someone on Craigslist has an LG listed as a "handyman special." The ad said the water level sensor has gone bad, otherwise the unit works well. I asked for additional detail, like how the issue manifests, and was told "with clothes in the washer the unit never reaches the rinse or spin cycle and eventually water comes through the door. However with no clothes in the unit it runs the cycle normally."
Does the water level pressure switch seem like a reasonable guess at the culprit, based on the observation above?
A switch seems to run under $20 on eBay. Next cheapest such washer on CL is $150 more than this person is asking.
huesmann is offline   Reply With Quote
Old 04-09-2019, 11:11 AM   #2
Rewards Points: 496
Re: Front Load Washer Water Level Switch
Pressure switch or bad water valve. Really have to check it with a meter to find out
BayouRunner is online now   Reply With Quote
2nd Floor Bathroom Leak KenOhio76 Plumbing 7 01-09-2018 02:10 PM
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
How to speed up a Samsung front load washer? AlanSD Appliances 3 05-26-2015 05:39 AM
LG Front load washer LarsFromMars Appliances 13 07-16-2013 11:04 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
