Fridge Icemaker Questions? - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2014, 04:08 AM   #16
Rewards Points: 6
Thats Rough
Try to google it.
Saved me many times.
Luke Champ is offline   Reply With Quote
Old 10-19-2014, 01:35 AM   #17
Rewards Points: 263
If your icemaker doesn't have a button (that another poster mentioned) that will make it go through the entire cycle, then you'll have to use a jumper wire and do it manually. Google your icemaker module. You'll find instruction sheets on which holes (in front of your icemaker) to insert the jumper wire. Your icemaker will then go through a complete cycle of heating up, ejecting ice, and filling up with water (this is when you'll know if the solenoid valve is working).
There's also another pair of holes you can insert the jumper wire into that will turn on just the solenoid valve. Sorry for all the "holes" and if they're vague but I don't remember all the hole labels off the top of my head. I remember one pairing is T-H and that's for the whole cycle, I think. It's been almost a year since I had to do jumper wire poking when I replaced my icemaker.
Druidia is offline   Reply With Quote
kenmore fridge won't cool str0sey Appliances 0 08-29-2011 03:52 PM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Fridge Diagnosed as "Unrepairable" Old Lady Appliances 9 06-28-2011 07:08 AM
Questions about icemaker and water line options littlehoov Appliances 2 11-04-2009 12:27 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
