Freezer Fan Excessive Cycling - Appliances - DIY Chatroom Home Improvement Forum
Old 09-07-2019, 08:57 AM   #1
Rewards Points: 6
freezer fan excessive cycling
My side by side Kenmore 253 51693105 stopped cooling in the refrigerator. I figured the evaporator was freezing up. Got that right. Defrost timer suspected as problem. I removed the timer and re installed it because I didn't see anything obviously wrong such as wiring or other visible issues. I let it run on the high settings overnight and the fridge dropped to 45 but no lower. I have a digital to ck temp. Could th defrost still be faulty and maybe causing the cycling problem?
toptech1275 is offline   Reply With Quote
Old 09-07-2019, 06:22 PM   #2
Rewards Points: 18
Re: freezer fan excessive cycling
When that happened to mine, it was the defrost thermostat that was bad. Simple fix, and inexpensive part, but I had to remove all of the shelves. And the panel at the back of the freezer compartment (inside the freezer). Go to repairclinic.com put in your model #. They have videos on how to diagnose the problem, and how to make the repair.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 09-08-2019, 09:46 AM   #3
Rewards Points: 6
Thumbs up
Good Morning
Thank you I will give that a try.
Michael
