Dishwasher Won't Drain Completely - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 06-16-2018, 09:47 AM   #1
Rewards Points: 18
Dishwasher won't drain completely
I have a GE dishwasher that leaves an inch of water at the bottom after almost every cycle. I know the drain isn't clogged because if I immediately start a new cycle, it drains quickly, (before starting the new starting the new cycle). It's almost as if the pump stops too soon when the cycle ends.
Does anyone have any ideas for what may be going on?
Thanks,
rkhpapa
rkhpapa is offline   Reply With Quote
Old 06-16-2018, 12:50 PM   #2
Rewards Points: 56
Re: Dishwasher won't drain completely
Certainly not an expert - but there may be a water sensor that senses how high the water is - then the pump runs timed off of that. If you post a specific model you may get more responses. You still could have a minor restriction in the screen /filter area.
tribe_fan is offline   Reply With Quote
Old 06-16-2018, 09:09 PM   #3
retired framer
Rewards Points: 4,328
Is the drain hose looped high under the sink??
Old 06-16-2018, 09:29 PM   #4
Rewards Points: 3,146
We had a DW with a similar problem and when i pulled it out to replace it found the discharge hose kinked.
Nealtw likes this.
Old 08-09-2018, 09:02 PM   #5
Rewards Points: 18
Did you get this resolved ? it could be a hose issue maybe a drain pump motor problem. could be a sensor issue or something could be a little clogged could be a issue with the control board!
mdh83 is offline   Reply With Quote
Whirlpool dishwasher not draining completely Lemkie Appliances 8 10-27-2015 11:24 AM
GE Dishwasher won't Drain on Last Cycle wkumtrider Appliances 3 10-10-2013 08:32 PM
Dishwasher drain valve opening WallyWoggle Appliances 1 01-12-2011 09:44 PM
dishwasher drain hose onelson Plumbing 4 03-16-2010 10:55 PM
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 11:56 AM
