Dishwasher Rubber Sump - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Druidia
Old 02-26-2018, 12:27 PM   #1
Rewards Points: 253
Dishwasher rubber sump
How often do you replace a dishwasher sump and when do you replace it? Do you do preemptive replacement?
I have a GE Triton XL. Itís a little over 14 YO. It still works well. Iím pretty consistent in keeping the parts clean - coarse/fine filters, filter basket (that fits inside the sump), spray arms, the tub floor, round the door gasket, etc.
The sump is made of white rubber and I noticed (felt it, actually) itís tacky - tacky like rubber gets when itís old. Should I be replacing the sump already or is a tacky old rubber sump normal?
Druidia is offline   Reply With Quote
Old 02-27-2018, 07:12 AM   #2
Rewards Points: 2,074
Re: Dishwasher rubber sump
Never, wait till it leaks then get rid of dishwasher.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-27-2018, 07:15 AM   #3
Rewards Points: 253
Oh? So if the rubber sump develops a leak, replace the whole dishwasher? Why not replace the sump? Are you recommending replacement because of the age of the DW?
Old 02-27-2018, 08:01 AM   #4
"Yes"
The Following User Says Thank You to COLDIRON For This Useful Post:
Druidia (02-27-2018)
Old 02-27-2018, 08:16 AM   #5
Property Mgt/Maint
Rewards Points: 7,382
AT 14 yrs, my biggest concern would be the supply line feeding the DW. One blown supply hose could be catastrophic in short order.
A leaking pump, or pump hose would only leak when pumping water. A blown supply hose will leak until a valve is shut off.
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 02-27-2018, 08:20 AM   #6
Rewards Points: 253
"Yes"
Fair enough. How long are dishwashers expected to last before being replaced?
I wouldnít mind a new DW though I tend to develop loyalty to my old stuff. I have a Pilot mechanical pencil and an NT cutter Iíve had since 1983. HA HA Remarkable when those things have a high probability of getting lost/being left behind.
Old 02-27-2018, 08:24 AM   #7
Rewards Points: 253
It doesnít have a flexible supply hose. It has a 1/4Ē copper tubing directly connected to the solenoid valve (as far as I remember last time I cleaned under the DW). Thatís actually the reason why I dread having to replace the rubber sump -
I hate having to work with stiff copper tubing + DW is heavy to pull out and tip over.
I do have a water leak alarm under the DW and outside the DW.
Yodaman likes this.
Old 02-27-2018, 10:05 AM   #8
Sorry I can't tell how long something should last. It's like a lifetime warranty how long is life? Everybody has their own preference of replacement time. I just got rid of a $3K refrigerator that was 8 years old. Bad compressor. I can replace it myself but I decided not to. Replaced with a new refrigerator. To each their own. How much aggravation and money will dictate that. Whatever you decide good luck.
Old 02-28-2018, 07:59 PM   #9
Rewards Points: 125
My kitchen aide lasted 16 years. Was working great but a little rust around the door hinge and some occasional drips. What killed it was the control board burning up. Filled the house with an acrid odor and entertained the neighbors with the fire department showing up. No harm done, dishwasher went out the door the next morning.
jimn01 is offline   Reply With Quote
Smelly dishes in dishwasher pb2 Plumbing 12 10-16-2017 12:50 PM
Installing New Dishwasher (Electrical Connection) pumpkinpatch Appliances 2 09-10-2017 10:12 AM
Bosch Dishwasher Odor Pasteycakes Plumbing 1 09-05-2017 08:56 AM
Installing dishwasher, are dishwasher panels needed? Lemkie Kitchen & Bath Remodeling 4 02-24-2015 05:13 PM
Sump pumps (indoor and outdoor) chrisificti0n Plumbing 13 10-15-2014 07:08 PM
