Direct Draining A Dishwasher? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-18-2019, 09:32 PM   #1
Mystriss's Avatar
Rewards Points: 4,566
Direct draining a dishwasher?
Is there any code against direct draining a dishwasher into the main sewage line of the house (septic not city)
Alternatively is there some kind of external pump add-on I can get to help get the water to the sink drain? (Dishwasher is quite a ways from the sink and the pump in it isn't handling the job adequately.)
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 04-19-2019, 06:13 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 914
Re: Direct draining a dishwasher?
IF your sink is too far away from the DW, yes, I would recommend a separate drain with a trap to handle the water. For the most part, dishwasher waste water is DW detergent, water and food particles, so I don't see a problem with septic nor sewer.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Mystriss (04-19-2019)
Old 05-05-2019, 01:53 PM   #3
Contractor/Engineer
Rewards Points: 1,170
As chadler48 said - "WITH A TRAP." Do not connect your washing machine drain DIRECTLY to the sewer - and don't forget a vent if you're going more than 8' with a 1/4" slope. If your slope will be greater than 1/4" per foot, then the vent has to be closer to the trap to prevent siphoning of the trap - which will lead to sewer gases coming into the dishwasher.
If confused about the vent, you could us an Air Admittance Valve.
Domo is offline   Reply With Quote
Old 05-06-2019, 11:27 AM   #4
Hammered Thumb
Rewards Points: 788
Take this as an alternate idea, not nitpicking. I seem to recall you remodeled your kitchen for $30+, wouldn't it be an easier and better solution to move the dishwasher to its proper location next to the sink? Plumbing solved with maybe a little cabinet work.
3onthetree is offline   Reply With Quote
Whirlpool dishwasher not filling - may be float switch lazzlazz Appliances 4 02-02-2018 02:10 AM
Smelly dishes in dishwasher pb2 Plumbing 12 10-16-2017 12:50 PM
Bosch Dishwasher Odor Pasteycakes Plumbing 1 09-05-2017 08:56 AM
Dishwasher not draining properly GRFagan General DIY Discussions 8 09-12-2015 07:23 PM
Dishwasher draining into basement laundry/sink system - venting? mathx Plumbing 1 03-22-2012 02:54 PM
