Dead Stove - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree30Likes
Old 05-13-2019, 10:08 AM   #16
Rewards Points: 6,507
Re: Dead stove
Originally Posted by Startingover View Post
She joined Consumer Reports. Itís surprising no stoves get high ratings.
Some of the smooth tops run 1,900
I said iíd buy an inexpensive for now. When it dies maybe induction smooth tops will have more kinks worked out
Have her or you do some more reading. Induction and glass tops sold at the BORG are two different critters though most inductions have glass tops.
Startingover likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-13-2019, 10:14 AM   #17
Rewards Points: 598
Re: Dead stove
The nerve wracking humming sound.
Startingover is offline   Reply With Quote
Old 05-14-2019, 03:49 AM   #18
Rewards Points: 824
Re: Dead stove
Installed an induction cooktop in a friends new house, they love it. It is super fast and I've never heard any hum or really any noise from it. Was expensive though, think they paid better than two grand for just a cooktop.
We've had a smooth top electric range in our house since 02, it really has been no issue. Spills can get cooked on if you don't wipe them up right away. Even when they do a razor blade will scrape 90% off quickly, the rest scrubs off pretty easy with a squirt of smooth top cleaner and a wet rag. Definitely no more difficult to clean up than any elec coil or gas cooktop. Not sure I even know anyone who still has a range with electric coils. Every one I've ever had gave constant problems where the burner coils plug into the top.
Never had any trouble with cast iron skillets on the smooth top, usually use stainless or aluminum non stick pans though. 17 years and it still looks like new. Bowed out pans do rock around but they still cook, they don't really work all that great on any other kind of stove either. When they get that way it's time for a new pan. I prefer the control of a gas range. We had one before getting the smooth top, but my wife didn't like having to take every burner and grate off to get it cleaned it up. Never liked having the knobs on the front either, the kids would manage to bump them on and wouldn't notice til we smelled gas. MUCH easier to just wipe off the smooth glass surface.
Not sure what kind of smooth top you are looking at, I just priced a new range as our oven has been occasionally failing to heat up. Went to a smaller, local appliance store in town and they had several brands on the floor around $700. Hard pressed to find any that were over about $1400 and those had convection or double ovens.
iamrfixit is online now   Reply With Quote
Old 05-14-2019, 08:07 AM   #19
Rewards Points: 2,064
Re: Dead stove
I guess this is just a personal preference. The stove that was in the house when I bought it was probably from the 50's. It had coils and worked fine until the day I blew it up (long story) sometime in the 90's or early 00's. I think I replaced one coil, which of course you could buy anywhere and it would fit.
The cheap model I bought to replace it also had coils, and performed perfectly until a couple of years ago when I re-did the kitchen. I sold it on Craigslist to a neighbor who was thrilled to get it. Before those I'd always used gas, which I much prefer but isn't available here.
Any old pot or pan, no matter how bowed, worked fine. Things heated up and cooled down relatively quickly, although not as quickly as with gas. I never needed to scrape with a razor blade or use special cleaners or color-coded pads to clean it.
Spills could be wiped up with a damp cloth as soon as they spilled. No waiting for the cooktop to cool. I could take a hot pot off one burner and put it on an unused one to cool. I could put a cold pot on a hot burner. I could use the burners as extra counter space for other pots and pans. I could slide the pots and pans around on the cooktop, and spin them to move the handle to a convenient spot. I could shake them back and forth on the burner to move the food around.
All of this is strictly forbidden by the manual that came with our new glass cooktop. I find it all very inconvenient.
Startingover and Bud9051 like this.
CaptTom is offline   Reply With Quote
Old 05-14-2019, 08:39 AM   #20
Rewards Points: 1,069
Re: Dead stove
We have gas in our kitchen, and an electric range outlet in the basementóPOs rented basement out. The electric range apparently died shortly before they sold, and they never replaced it. The wife likes induction, because she had induction in her family growing up. We could have run electric to the kitchen, but just bought the house and are cash-poor, so that's on the back burner (pun intended). But I was able to find an induction range on Craigslist that the seller indicated the oven wasn't working, i.e. getting hot. I bought it for $150. Got it home and found that the outlet needed to be changed to fit the plug. That sat around while I fried bigger fish. Recently got that part done and found that the cooktop worked just fine, and the broil element in the oven worked, but the bake element was hosed. Unscrewed the bottom panel and found the attached. Apparently the element had melted apart at some point. Got a replacement element on eBay for under $30, replaced it, and it works great.
huesmann is offline   Reply With Quote
Old 05-14-2019, 02:37 PM   #21
Rewards Points: 74
Re: Dead stove
CPTTOM
The "glass" is sometimes not just glass. It is more of a mix if glass and ceramic. I think some of the first smooth top ranges were glass, but were tempered and tougher than one might think. Yes you can set a scorching hot pan onto a burner that was not on and there will be no ill effects. They are not difficult to keep clean. The key here is that you must clean up after you are finished and not re heat the burner and place a pan on it before the original spill is addressed. Before I moved to induction I had a smooth top for several years which looked show room clean up until the day I sold it. So if you have poor cleaning habits then a smooth top using radiant cooking technology is not for you.
Induction: A wonderful technology I embraced about 10 years ago and will never go back to radiant technology again. Let me start off by saying the cooking surface is easy to maintain because the surface does not produce heat. However there is residual heat between the pan and the surface so it will get hot, just not as hot as electric resistance. Spills of water, sauce and a variety of other foods are no big deal. Clean those after you’re done preparing your meal. Sugar and salt are another matter. These spills need to be addressed immediately or it will scar/damage your cooking surface. Sliding the pot on top of these minerals will also cause damage...don't do that. The really cool part is that you can actually put a paper towel, parchment paper, newspaper and even a towel between the cook top and the pan to catch drips and such and still cook. Although avoid the setting referred to as "boost" when using newspaper or towels. This is a bit too much for those material and they will at a minimum smoke and possibly com bust. My favorite material is a SIL-PAT cooking mat. It is a silicone material rated at 450 degrees F and I cook on these all day every day. Amazon has some cool colored one I purchased as well. These will help keep your induction cook top looking beautiful.
The Hum: This a function of the pan itself, not the stove/cook top. If you have cheap pans. I am not going to go into details about manufacturing methods of cookware. If you are going to use this technology and the humming bothers you, buy good quality pans or even cast iron. One does not need to spend $2000 on a set of pans, however I would probably steer clear of the Walmart specials. You can always go home fill the pot with distilled water (lessen the likely hood of staining) turn it on full power and see if it passes the hum test. If not take it back and try again. Distilled water is like $1.00 for a gallon..cheaper than petro.
Brands: Personal experience, stay away from Samsung. It's junk in a box. This is not just for stoves either, they sell a lot of crap...literally. They sell a lot of it and it's crap. I am surprised they are still in business. Typically luxury brands tend to fair a bit better in the reliability department than others. I am referring to brands such as Wolf, Bosch, Miele and Thermador to name a few. The GE Cafť series is absolute trash as well. If you are concerned about cost of the appliance and still want it, get the warranty. They are more expensive to obtain and more expensive to repair when/if they crap out.
Theory on my part, no hard evidence to support this. Avoid the self-cleaning feature of the ovens if you buy a range. It is my belief that the electronics are overheated and the cooking surface and possible the oven itself suffers failure due to this. Again, nothing to back this up other than many internet accounts of this occurring and I was a victim as well. Keep it as simple as possible. I know we want all these features, however the less features you have the less likely for something to break. You’re just cooking, you need the surface to get your pan hot and respond to commands in temperature, nothing more. You don’t need WIFi and timers and a host of other useless features. If you get a cook top make sure it can breathe and the clearances are with the manufactures specification. I have personally gone through two ranges. My first a Samsung then a Whirlpool. My current rendition is A Featureless Frigidaire Professional series Cooktop after a kitchen remodel and it has been going strong for several years, YMMV.
kevinande is offline   Reply With Quote
Old 05-14-2019, 06:53 PM   #22
Re: Dead stove
Mine is just a couple of years old. I'm going by what the manual says. Never put a hot pan on a cool burner. Never slide or spin a pan on the surface. Never wipe with a damp cloth while hot. Never put a cool pan on a hot burner. Only use special cleaner, and a special kind of scrubbing pad. Never cook anything before completely cleaning up from last time.
PITA if you ask me. And even doing everything right, it's not quite showroom new looking any more.
You're right. It's not for me.
Old 05-14-2019, 07:48 PM   #23
Rewards Points: 824
Re: Dead stove
Have done all those things a million times and it's no worse for the wear. Ours usually gets wiped with a wet rag whenever something spills. Often I'll just slide the pan over and wipe around the burner while it's still on.
Maybe once or twice a year something will spill and leave a burned on ring around the edge of the burner. I just lay a wet dish rag on it for a while, then a quick scrape with the razor blade and scrub off the rest with cleaner and a wet rag. Have the same bottle of smooth top range cleaner we got when we got the stove. 17 year old maytag, it's working for me.
Old 05-15-2019, 10:26 AM   #24
Rewards Points: 4
Re: Dead stove
A couple of points. We do canning, using a 20 quart water bath canning pot. That's over 40 pounds. I've read that these can crack a glass/ceramic top stove. Also, water always boils over, and as the pot cools, the water around the edges of the bottom can seal the pot to the cooktop. I downloaded a manual for a smooth cooktop. The restrictions do not fit our casual lifestyle.
I've repaired the burners/outlets on my coil cooktop several times. It's easy and costs around $30, compared to well over $100 for replacing a heating element on a smoothtop. (Since this is the DIY Chatroom, I assume that being able to do such things yourself is part of the equation.)
We have a single "burner" induction cooker. They do not work with aluminum or some types of stainless steel. So if you get one, you may also be buying new pots and pans. You can check your current pots and pans with a magnet. Induction requires pots and pans that a magnet sticks to.
I'm saddened by the lack of choice for coil electric cooktops. Mine is quite old, but finding one the same size is nearly impossible. Gas is not available where I live, and the glass/ceramic cooktops are simply not as rugged.
Startingover and CaptTom like this.
rplantz is offline   Reply With Quote
Old 05-15-2019, 02:01 PM   #25
Rewards Points: 204
Re: Dead stove
HK, compared to cost of a new range replacing a switch might be worthwhile. I'll pass that on to her. At least I can call and get repair estimates for her.
If you can find the switch online, replacing it yourself might be an option.
A repair man is probably going to charge you north of $100.
DallasCowboys is offline   Reply With Quote
Old 05-15-2019, 03:45 PM   #26
Rewards Points: 2
Re: Dead stove
The "eyes" or elements are CAL ROD and you are describing a classic failure mode
The burner can be replaced for $25
It is as easy as unplugging the old and plugging in the new probably can find on YouTube
The model number is usually bottom left drawer corner for a range or under (bottom pan) for a cook-top. A site like searspartsdirect.com has parts diagrams to identify the part number/wattage
Make sure to unplug or trip the breaker (240V)
CRAZYAKS is offline   Reply With Quote
Old 05-15-2019, 06:15 PM   #27
Rewards Points: 18
Re: Dead stove
Anyone considering an induction stove: Keep in mind you'll have to get new pots and pans that are induction compatible. Regular ones won't work.
mitchleeanderso is offline   Reply With Quote
Old 05-17-2019, 09:32 AM   #28
Re: Dead stove
Shrug. Many "regular" pots and pans work.
Old 05-19-2019, 09:08 AM   #29
Rewards Points: 598
Re: Dead stove
Welk, after paying for nee AC an pricing even simple stoves she decided to repair existing stove
Shes good at replacing outlets or anything where she can match old wires to new wires.
She asked me if the ďswitchĒ only has 2 wires.
Haha, like Iím supposed to know. Or, like moms always know the answer!
Does anyone here know? Yes, iíll give you credit an not pretend Iím a genius with the answer.
Old 05-19-2019, 09:11 AM   #30
Rewards Points: 478
Re: Dead stove
Probably 4 or 5 wires. Really not a hard repair but if itís a glass cooktop itís a pita because the whole top needs to be removed in most cases.
BayouRunner is online now   Reply With Quote
Stove outlet Merandi Electrical 4 05-13-2012 01:51 AM
Replacing Electric stove w/ gas stove PMV Appliances 3 01-02-2012 02:00 AM
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 11:04 AM
Parlor Stove Retrofit?? Master Brian HVAC 6 11-20-2010 01:19 PM
