Cooktop Fitting Question - Appliances - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By huesmann
  • 2 Post By Koa
Old 10-15-2019, 10:39 PM   #1
aam
Rewards Points: 12
cooktop fitting question
Hi,
For our new home we selected a 36 inches kitchen aid electric cook top. The cut out done for the kitchen aid cook top was width: 35 5/16 inches and depth: 20 1/2 inches.
unfortunately the kitchen aid cook top got some issue with the touch and kitchen aid has recalled the model.
Now we have selected a 36 inches Bosch induction cook top. The cut out specification say width between 34 3/4 to 34 7/8 inches and depth between 19 7/8 to 20 inches.
Could any one suggest that it is OK to install the Bosch cook top in the cut out done for the kitchen aid cook top.
thanks
aam is offline   Reply With Quote
Old 10-16-2019, 12:07 AM   #2
JUSTA MEMBER
Rewards Points: 1,574
Re: cooktop fitting question
That is for you to decide.
Measure the new, exactly, and if there is enough flange for it to not fall through the existing hole, you probably are "good to go".
But if there is a chance that it might fall through, I would fashion some fillers from 1/2 inch aluminum angle iron, with spacers between the filler and the countertop rim, so that when screwed to the countertop, it creates a hole sized to keep this new one topside.
That's me, what you decide to do is not my place to order.
ED
de-nagorg is online now   Reply With Quote
Old 10-16-2019, 08:57 AM   #3
Rewards Points: 2,176
As an alternate idea, perhaps you could give it some extra support from below the cooktop, with some steel channel stock across the cabinet, held up by some cleats on the cabinet walls.
de-nagorg likes this.
huesmann is offline   Reply With Quote
Old 10-16-2019, 12:19 PM   #4
Koa
Rewards Points: 174
Check with Bosch if they have a filler trim kit. Search for for filler trim kits. Here’s a company that makes them.
http://www.microtrim.com/cooktop.htm
de-nagorg and tdisss like this.
Koa is offline   Reply With Quote
