Central VAC - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2017, 10:28 PM   #1
siggy312's Avatar
Rewards Points: 64
Central VAC
Which is "best".
Installing an outlet cover as a 'pull-down' or as a 'pull-up".??
siggy312 is offline   Reply With Quote
Old 03-21-2017, 12:12 AM   #2
Rewards Points: 80
Re: Central VAC
Preference.
Pulling up, means that there's less chance to accidently open it while moving something heavy and tearing it off. It's not the biggest risk.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
siggy312 (03-21-2017)
Central air vs mini split Gerard120 Appliances 13 03-23-2017 06:14 AM
No hot water but central heating is working (conventional boiler) jxm Plumbing 14 01-05-2015 05:08 PM
Going from Central A/C to Mini-Split TysonS HVAC 1 11-29-2014 02:19 PM
Central Heat Blowing Cold Please Help blueprint99 HVAC 0 10-23-2013 12:34 AM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
