Carrier Furnace Pressure Switch Fault Code - Appliances - DIY Chatroom Home Improvement Forum
Old 01-25-2019, 09:00 AM   #1
Rewards Points: 4
Carrier furnace pressure switch fault code
I have been trying to figure out why my furnace will run for a couple minutes and stop after throwing a pressure fault code. I really don't know anything about furnaces, but I took the hose off the pressure switch opposite the one that goes to the combustion chamber and blew in it and there was a lot of gurgling from water. I proceeded to suck all the water out of that hose and sure enough the furnace ran up to temperature and held the temp. Since then that area the hose leads to filled up with water and I had to suck it all out again. The drain lines from the furnace are clear and flowing. Can anybody tell me where that hose is leading to (it is leading to the area behind the inducer motor. Also why this may be happening and what I should do about it.
It is supposed to be -10 here this week and would love to get this figured out.
hentz5 is offline   Reply With Quote
Old 01-25-2019, 11:00 AM   #2
Rewards Points: 1,332
Re: Carrier furnace pressure switch fault code
There is an clog somewhere in the heat exchanger that is not allowing water to flow out of it. Without seeing pictures or at least having a model # it will be hard to diagnose from here. Something to check though is how the furnace sits. Most all condensing furnaces need to be tilted forward to a degree (specified in the manual) to allow water to drain properly.
Dan
danpik is offline   Reply With Quote
Old 01-28-2019, 05:07 PM   #3
Rewards Points: 949
Check out this part..it is the Condensate Water Drain Trap:
https://www.ebay.com/itm/Carrier-Bry...item2397e0a1ad
If this part is plugged it will cause the symptoms you describe.
DanS26 is offline   Reply With Quote
Can't drain electric water heater dubina Plumbing 35 08-02-2017 09:07 PM
Bryant furnace pressure switch Red Squirrel HVAC 4 03-03-2015 08:10 PM
Heil furnace Pressure Switch issues heilProblems HVAC 6 02-12-2015 09:33 AM
Bryant Furnace Pressure Switch Problem dmichel HVAC 6 02-12-2013 04:43 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
