Cantilevered Bumpout With Water Infiltration Issues - Appliances - DIY Chatroom Home Improvement Forum
Old 10-15-2017, 11:07 AM   #1
Cantilevered Bumpout with water infiltration issues
I have a cantilevered bump (2'x4') out that has a patio door in it. If that's not bad enough there's a deck attached to it with no flashing on the ledger. So plenty of rot to repair. When replacing the outside joist How do you support the wall above?
Cantilevered Bumpout with water infiltration issues-img_1537_1508079996970.jpg
Craigm7513 is offline   Reply With Quote
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 09:57 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater issues Missydo Plumbing 17 04-05-2005 10:31 PM
