Can I Put Items On Top Of My Refigerator Or Freezer - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By huesmann
Old Yesterday, 11:22 AM   #1
Rewards Points: 232
Can I put items on top of my refigerator or freezer
I have an upright freezer in a storage room that I want to store a rubbermaid tub (doesn't weigh much at all, has artificial flowers in it) on the top of. I ran a couple of 2x4's across the top and put the tub on that. Now the tub does not cover the entire top surface, it is only about 18inches wide, the freezer about...30 inches or so. It is a big freezer. Will the 2x4's allow enough air flow? I have been told that freezers and refrigerators need to exhaust heat through the top surface. If that is the case I don't understand how people put cabinets down to them?
FrillyLily is offline   Reply With Quote
Old Yesterday, 12:35 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 618
Re: Can I put items on top of my refigerator or freezer
Freezers need air space to expel heat from wherever the coils are located, usually at the bottom or the rear. I can't say I've ever seen a fridge or freezer with the coils at the top except the very early ones.
I think you would be good to go provided the articles aren't too heavy. If the freezer is up against a wall try not to push things all the way to the rear so air can circulate.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old Today, 08:27 AM   #3
Rewards Points: 1,626
If there is still room for hot air to pass by it, you should be fine. I wouldn't have even bothered with the 2x4s.
joecaption likes this.
huesmann is online now   Reply With Quote
