DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Appliances (https://www.diychatroom.com/f47/)
-   -   air conditioning (https://www.diychatroom.com/f47/air-conditioning-110300/)
naemicarl 07-10-2011 08:45 PM
air conditioning
my blower on my lennox 80mgf(x) furnace won't run, the compresser will come on when you lower the temp.!
naemicarl 07-10-2011 08:50 PM
Lennox air conditoning
the blower on my furnace that supplys air flow for the air condoning won't run
diyorpay 07-14-2011 03:00 PM
Could be motor. Could be a board, especially if multi-speed fan.
Repost under HVAC section for expert replies.
Doc Holliday 07-15-2011 12:17 AM
Do you have a digital meter with mfd capability?
I'd start at the run capacitor. Even if you don't own a meter it is less than $15 for new run cap (you'd need to get the numbers from the old cap first and get the exact same spec'd cap) and it is needed to start the motor so you may get lucky and that be it.
There are sometimes tell tale signs that the capacitor is bad such as it's blown so the top where the electrical prongs are or the bottom would be rounded and curved versus flat as when not blown. Or there could be the gooey, thick, oily, jell substance leaking out of it somewhere. You'd have to inspect it and see.
Make certain you turn the breaker to the blower off before you do anything, not just the thermostat.
This would be the first thing I'd check as it's a pretty common problem as well as the cheapest fix.
http://www.bestbuyheatingandaircondi...01/CAP6370.jpg
The 5uf and minimum 370 volt numbers are what you'd be looking for on yours. Yours might not be a 5uf but you get the idea. Like for like.
Let us know.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
