Adjust Tension On Stove Knobs? - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 05-11-2017, 01:28 PM   #16
Rewards Points: 266
Re: adjust tension on stove knobs?
I asked somebody i know - if i turn the knob halfway without turning it all the way to light the pilot, will gas still come out? He said yes. Are you saying that's not true? If so, that makes me feel a lot better. When i get the stove and it gets hooked up, i'll test that.
flobiwan is offline   Reply With Quote
Old 05-11-2017, 01:50 PM   #17
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
I can tell you that a GE Profile will allow gas without ignition...
MTN REMODEL LLC is offline   Reply With Quote
Old 05-11-2017, 02:41 PM   #18
Rewards Points: 3,192
Our Whirlpool WILL NOT light without 120V. Not with a full box of kitchen matches or a propane torch. There is no gas to ignite without 120V AC power.
The manual even goes to the trouble of stating how clean the current of a portable generator should be to avoid damage to the electronics.
Broken stove top burner knobs, burner on. Nik333 Appliances 26 07-05-2016 08:27 PM
Wall Prep for Wood Burning Stove Install Kory Beam Building & Construction 10 04-02-2015 01:24 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
