When Is It Time... - Automotive Repairs - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree62Likes
Old 07-01-2016, 05:08 PM   #46
JUSTA MEMBER
Rewards Points: 1,512
Re: When is it time...
Originally Posted by 4t7 View Post
Also @de-nagorg I think I'm gonna go ahead and take your advice on replacing all the rubber fuel lines and clamps. I just re-read your reply last night about how they develop tear in the INNER lining...so a visual inspection like I did probably not very effective if the tear is in the lining, huh? Do you know if anyone sells a kit that comes with all necessary hoses and clamps for this?
I do not know of any kits for specific vehicles.
What I always do is to buy about 2 feet of the proper size hose, and a half dozen or so quality clamps, that way I have enough to do the task.
It is hard to tell on the inside of the old hose unless you split it open with a knife, but this ruins it anyway.
Fuel does age the rubber liner and it will decay . It is just a matter of time.
Did you see my tip on examining the steel line for a pinched off spot also?
A customer was having this kind of troubles, and it turned out that they had hit a log in the road and crushed the steel line right where it exits the frame in the front.
had to splice in a replacement line and they were on the road once more.
ED
4t7 likes this.
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
4t7 (07-01-2016)
Old 07-01-2016, 07:27 PM   #47
Tizzer's Avatar
Rewards Points: 148
Was 22-23 yrs. old when I bought an Olds 442 convertible from my boss at an Exxon station for $1200.
Gold with a white top and a 455ci motor. Was into the drag racing scene at the time and blew the transmission up. $$$ Still have the scar on my thumb from slicing it open while changing the metal intake manifold gasket. lol
Got married and thought I'd settle down so "we" traded it in for a Ford Ranger.
The payments lasted longer than my marriage.
r0ckstarr, de-nagorg and 4t7 like this.
Tizzer is offline   Reply With Quote
The Following User Says Thank You to Tizzer For This Useful Post:
4t7 (07-01-2016)
Old 07-01-2016, 11:07 PM   #48
4t7
Rewards Points: 12
ED
Alright will probably just do it that way. What is the proper name of the clamps btw?
I must've missed that part about the steel lines. I have checked them over a couple times before though and they appear in good shape; no pinches or cut bends or anything. The rubber hoses do look pretty worn though...will be doing those in a couple days.
Thanks again man! 🙋
4t7 is offline   Reply With Quote
Old 07-01-2016, 11:14 PM   #49
4t7
Rewards Points: 12
I 💙 these cars stories. Thanks for this one. Bad*** car too, and for $1200; not bad. How many years ago was this? Late 80's?
"we" 😁 hahah. Sorry to hear it didn't last long. 🍻
Old 07-01-2016, 11:27 PM   #50
JUSTA MEMBER
Those clamps are sold as GEAR CLAMPS, they are a band with slotted holes , and a worm gear that tightens the clamp.
I remove all the factory clamps on my vehicles, toss them, and replace them with these.
A much better seal, and not an arm ripper like those stupid wire spring crap.
ED
4t7 likes this.
4t7 (07-02-2016)
Old 07-02-2016, 12:08 AM   #51
4t7
Rewards Points: 12
Gear clamps...Alrighty then. Excellent. Thanks man @de-nagorg !
de-nagorg likes this.
Old 07-04-2016, 12:40 AM   #52
4t7
Rewards Points: 12
Originally Posted by 47_47 View Post
I'd also check with a vacuum gauge. You may have a restricted exhaust causing low power or poor acceleration.
Thanks for the tip @47_47 !
Any advice on how to do this test?
Old 07-04-2016, 12:46 AM   #53
4t7
Rewards Points: 12
Originally Posted by r0ckstarr View Post
The interior was shot. After ripping most everything out, all it had was 2 seats, a steering wheel, and a dash. I ended up selling it to a guy who was going to take it to Mexico for $200.
I sold it because I got tired of messing with it.
Hahaah, wonder what he had planned for that car in Mexico..
Old 07-05-2016, 10:32 AM   #54
What is that?
Brainbucket's Avatar
Rewards Points: 1,754
Before you go and replace the rubber fuel lines, get a fuel pressure gauge and tape it to the windshield and drive the vehicle. If the fuel pressure moves to the no go zone then address that. If it does good then look for the system that isn't working correctly. It will get expensive throwing parts at it and may as well create another problem.
r0ckstarr and 4t7 like this.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
The Following User Says Thank You to Brainbucket For This Useful Post:
4t7 (07-05-2016)
Old 07-05-2016, 02:15 PM   #55
4t7
Rewards Points: 12
@Brainbucket , where do you recommend I hook the pressure gauge up to?
Old 07-05-2016, 02:53 PM   #56
Bigplanz's Avatar
Rewards Points: 2,622
If it has a schreader valve, use that. If it has none, splice in the line between the filter and the regulator and put the pressure gauge there. There are kits that have the attachments needed to splice into a line.
4t7 likes this.
Bigplanz is offline   Reply With Quote
The Following User Says Thank You to Bigplanz For This Useful Post:
4t7 (07-05-2016)
Old 07-05-2016, 04:29 PM   #57
4t7
Rewards Points: 12
No schrader valve on this van, ****
Brainbucket is right too, it IS getting expensive just tossing $$ at this van...money I ain't really got. Think I'm in over my head on this one boys. Really close to just callin' it quits...probably time to move on anyways.
Old 07-06-2016, 07:51 AM   #58
r0ckstarr's Avatar
Rewards Points: 82
Is this a TBI motor?
4t7 likes this.
r0ckstarr is offline   Reply With Quote
Old 07-06-2016, 10:28 AM   #59
What is that?
I don't think that vehicle has a fuel pressure test port. I go to the fuel filter and tap in the outlet side of filter. There are fittings that make it easy. But you may have to modify the hose length so you can see it. Tape it to the body and drivers window and go.
Old 07-06-2016, 11:23 AM   #60
4t7
Rewards Points: 12
Yes, it's a 95' TBI chevy 5.7L 350 engine.
Has almost 180,000 on the motor. Been regularly serviced/maintained most of it's life. But had sat for around a year before I bought it. I'm the 2nd owner.
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
My first time playing (literally) with mains power Red Squirrel Electrical 16 05-16-2012 03:58 PM
shelves and cure time 7echo Painting 5 04-02-2012 09:27 PM
How do I change the time? MNsawyergp Site Help and Suggestions 4 02-14-2012 07:25 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 05:13 PM
