WaterPump - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree6Likes
  • 1 Post By F250
  • 1 Post By 3onthetree
  • 1 Post By Brainbucket
  • 1 Post By Gottawireitup
  • 1 Post By F250
Old 05-13-2019, 11:18 AM   #1
Gottawireitup's Avatar
Rewards Points: 40
WaterPump
I installed a new aftermarket waterpump in my Tiguan. This one is fully metal versus the cheap plastic VW. There are 5 bolts that go into engine block.
I screwed them all and and was careful not to overtorque. The issue is that one of the bolts is not snug like the other 4.
In a perfect world I would retap the block.
The question is will I get away with leaving it. 4 of the bolts are snug and secure. 1 is right but continues to spin if you turn it.
Gottawireitup is offline   Reply With Quote
Old 05-13-2019, 12:26 PM   #2
Rewards Points: 1,850
Re: WaterPump
In murphy's law, that's the bolt that will leak coolant.. Imo, If it keeps spinning around that loosely, I wouldn't trust it. You know, vibration, the constant movement when car is in motion bumps, etc.
You could take a chance and hope for the best. If you are not going to retap then at least put thread sealant on all the bolts. Some kind of Locktite sealant etc.
jmon is offline   Reply With Quote
Old 05-13-2019, 12:31 PM   #3
Oso954's Avatar
Rewards Points: 1,208
Re: WaterPump
My money would be on guaranteed to leak. If not immediately, shortly thereafter.
Oso954 is online now   Reply With Quote
Old 05-13-2019, 01:40 PM   #4
Still learning every day!
F250's Avatar
Rewards Points: 692
Re: WaterPump
It's sometimes painful to have to rework something to make it right, but you're never sorry that you did it afterwards!
On the other hand, skipping a critical step is only worth the risk if you don't mind the pain and inconvenience of tearing everything out to get back into that same spot to rework it at a later date.
Don't forget, too, that things only break when you are using them and need them to work! That's typically the worst time to develop a repair plan on a vehicle because the fact that it broke while you're using it and relying on it means that you're also AWAY from HOME and do NOT have YOUR tools and resources to do the work!
Do it right the first time and call it DONE.
Dave Sal likes this.
Pete
Bark less, wag MORE, and Show Compassion to everyone you meet!
F250 is online now   Reply With Quote
Old 05-13-2019, 01:49 PM   #5
Hammered Thumb
Rewards Points: 1,118
Re: WaterPump
Just asking, but did you reuse the bolts and put them in the same spots? Some may be slightly shorter. Just asking.
3onthetree is offline   Reply With Quote
Old 05-13-2019, 02:53 PM   #6
Rewards Points: 40
Re: WaterPump
I used new bolts that were the same size and put them in the appropriate holes.
Old 05-13-2019, 04:46 PM   #7
Dave Sal's Avatar
Rewards Points: 726
Re: WaterPump
You can buy a cheap (less than $20) tap and die set from Harbor Freight.
https://www.harborfreight.com/hand-tools/tap-die.html
Dave Sal is offline   Reply With Quote
Old 05-13-2019, 05:28 PM   #8
Hammered Thumb
Re: WaterPump
I asked that b/c you didn't specify any cause with the original bolt or putting the new one in. Test the old bolt, if same result, then tap it. Just wanted to make sure b/c there isn't too odd an angle and you're not torqueing the pump bolts like on a head, so it should be harder to strip.
ron45 likes this.
Old 05-13-2019, 06:52 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 1,652
Re: WaterPump
If you go the tap and die route, you probably want to use metric, otherwise that new bolt and hole may be the only SAE one on the vehicle.
Are you certain all the bolts and holes are the same diameter and depth? Normally one would think so but unusual design situations exist.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 05-13-2019, 10:14 PM   #10
Rewards Points: 40
Re: WaterPump
I would do tap and die if I had a bit more experience. At this point - sadly - have to tow it to shop. Will also save me huge hassle putting everything back again anyway.
Anything I need to worry about in terms of disconnected fuel lines? I believe itís disconnected at the high pressure fuel pump.
Old 05-14-2019, 10:15 AM   #11
Rewards Points: 1,069
Re: WaterPump
If you're just having it towed, no need to worry about fuel lines, as long as they're plugged.
huesmann is offline   Reply With Quote
Old 05-14-2019, 10:20 AM   #12
What is that?
Brainbucket's Avatar
Rewards Points: 1,494
Re: WaterPump
If the bolt is turning without tightening and the bolt threads are good, the hole is now bigger. Now it's Heli-Coil time.
raylo32 likes this.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 05-14-2019, 05:49 PM   #13
Rewards Points: 40
Re: WaterPump
Ya. Got a mobile mechanic coming now who has lots of experience. For a DIYer this sucks but money is worth not having to deal with this issue anymore.
I tried
Old 05-14-2019, 08:01 PM   #14
Rewards Points: 894
Re: WaterPump
As Brainbucket said Heli-Coil was the life saver.
Canarywood1 is online now   Reply With Quote
Old 05-15-2019, 08:22 AM   #15
F250's Avatar
Rewards Points: 692
Re: WaterPump
Just make sure to ask the Mobile Mechanic to pack his drill bit and tap with grease to make sure that all metal pieces get captured and removed so they don't end up circulating through your engine and potentially accumulating into a flow restricting knot somewhere inside your block.
ALSO... if you can, make sure that you watch him do the job... you'll be prepared to do something similar at a later point instead of having to call someone in to finish the job.
Pete
