Water Pump - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree77Likes
Old 10-31-2019, 10:39 PM   #1
Rewards Points: 1,156
Water pump
My Toyota was making a sound for 2 months. A man yrs ago said if no dash lights come on, youíre ok.
This was a rubbing noise behind glove compartment, but in the engine. I thought of looking, like for something frayed. But thought no I wouldnít know what I was looking at.
I only drive 5 miles to work so didnít worry. But I want to go to the mall and was leery of driving farther so took my car to the shop.
Dang, water pumps aren't cheap.
The shop also wanted to repair my headlight glass thats all foggy looking but I said no, I just wont drive at night.
Nealtw likes this.
Startingover is offline   Reply With Quote
Old 11-01-2019, 12:06 AM   #2
JUSTA MEMBER
Rewards Points: 8
Re: Water pump
About that headlight.
Glass or plastic lens?
Headlights were all glass many years ago, now they are a plastic lens over a filament bulb.
If a glass one the thing is shot, and needs replaced.
If plastic lens, it can be polished and the haze will go away.
Takes a polish made for them, buy at a parts store.
Yes water pumps are expensive, plus the labor charge.
At 5 miles your engine won't get hot enough to matter much, but farther and you will overheat, good thing you had it checked out.
Also at just 5 mile commute it ain't getting warm enough to keep carbon build-up from accumulating on the spark plugs, and valves.
This causes premature DEATH of the engine, take it out on the interstate at least once a month, and get up to higher speeds for a half hour or so to blow those carbon deposits out.
Your car will thank you, by running better, and lasting longer.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Startingover (11-01-2019)
Old 11-01-2019, 08:05 AM   #3
Re: Water pump
Thks, I heard that many years ago about engines but didnít know it was still true.
I could drive down to Orlando, to shop and get my car out on the highway but now I wonít have any money to shop after paying this repair bill.
de-nagorg likes this.
Old 11-01-2019, 08:15 AM   #4
Rewards Points: 1,436
Re: Water pump
Thats the worse advice that exist, id say 90% of troubles in car will result in no warnings lights, bad brakes, bad belts, bad suspension, bad steering,...
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
Old 11-01-2019, 08:44 AM   #5
retired painter
Rewards Points: 568
Re: Water pump
If the headlight haze is on the outside it can be buffed clean although often it will need to be repeated in a yr or so. If it's moisture on the inside of the lens, the headlight assembly needs to be replace. Normally that isn't a difficult job. Depending on they type of car [size of headlight assembly] the aftermarket ones run between $25 and $125 each.
Startingover likes this.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Old 11-01-2019, 09:02 AM   #6
What is that?
Brainbucket's Avatar
Rewards Points: 1,700
Re: Water pump
http://www.autolightsbulbs.com/
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 11-01-2019, 09:03 AM   #7
JUSTA MEMBER
Rewards Points: 8
Re: Water pump
You are a rare woman indeed.
I've never met one that needed money to shop.
They shop at the mere suggestion, now purchasing , that's a different story.
ED
Startingover and 123pugsy like this.
Old 11-01-2019, 09:03 AM   #8
Re: Water pump
Iíll look at the headlights when I get my car back. I think theyíre glass and haze is outside
I suppose its road debris that marred them?
Old 11-01-2019, 09:06 AM   #9
retired painter
Rewards Points: 568
Re: Water pump
Debris and UV rays. As far as I know glass headlights went out with the sealed beam bulbs. Modern day cars have a 'plastic' headlight housing with a bulb inside it [accessed from the rear of the assembly]
Old 11-01-2019, 09:53 AM   #10
ukrkoz's Avatar
Rewards Points: 1,358
Re: Water pump
What year is that Toyota?
Headlight can be hand restored in about 20 minutes with very little expense, if it's polycarbonate.
ukrkoz is offline   Reply With Quote
Old 11-01-2019, 10:32 AM   #11
Rewards Points: 408
Re: Water pump
Some 2000 grit wetsanding and some elbow grease with some polishing compound.
huesmann is offline   Reply With Quote
Old 11-01-2019, 10:53 AM   #12
Re: Water pump
i just use some car compound or you can try dental paste
Old 11-01-2019, 11:10 AM   #13
Re: Water pump
2007 Corolla
Old 11-01-2019, 11:24 AM   #14
JUSTA MEMBER
Rewards Points: 8
Re: Water pump
2007 Corolla
That new they will be plastic lenses.
If the fading is not bad, I use WD-40, to restore them, but if hazy too much, polishing compound from a can sold in the automotive section will work.
Application of WD-40 every 6 months to a year, and mine don't haze over.
Amazing what WD-40 is able to do.
ED
ps
Applied with an old sock that has developed a hole or two.
Old 11-01-2019, 02:14 PM   #15
Re: Water pump
Florida- we donít wear socs.
Iíll find an old rag.
de-nagorg and mark sr like this.
