Torque Wrench With Or Without Case? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-19-2015, 11:25 AM   #1
Solidify's Avatar
Rewards Points: 834
Torque Wrench with or without case?
A while ago I purchased this torque wrench on sale at $50 (tax incl.), which is 50% off its original $99.99 price.
Today, the store has put a presumably better model of the same torque wrench on sale for $80 (tax incl.), which is 50% off its oroginal $144.99 price.
I'm tempted to exchange mine for the better model simply because it comes with a case, which I've read is important for a delicate item like a torque wrench. Is the extra $20 justifiable for wanting a case? This will be only for swapping winter and summer tires on two cars (lug nuts), twice a year. I'm not a mechanic, I'm a homeowner. The torque wrench I have now has worked well for me so far, I'm just worried about one day dropping it.
Solidify is offline   Reply With Quote
Old 02-19-2015, 12:21 PM   #2
Low Slope Roofing
Rewards Points: 114
I wouldn't worry about it. If your going to drop it most likely it will be out of the case anyway. Mine all have cases but they come out of the case once I need to use them. I don't walk with it from the tool box, to the project with it in the case.
They do help if they happen to be in a draw with a bunch of other tools. A towel or rags would do the same thing.
1985gt is offline   Reply With Quote
Old 02-19-2015, 12:39 PM   #3
Solidify's Avatar
Rewards Points: 834
I hate to be the guy that asks for advice then doesn't take it but I think I'll regret not getting the one with the case if I pass up this sale, which comes once a year, if I'm lucky. I've been watching for it too (the sale).
Like most professionals say, spend the money the first time, and your tools will last.
Thanks anyways 1985gt.
The Following User Says Thank You to Solidify For This Useful Post:
1985gt (02-19-2015)
Old 02-19-2015, 12:55 PM   #4
Rewards Points: 1,466
Wrap it in bubble, news print or other padding and slip it into a piece of PVC with end caps. No glue necessary.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
1985gt (02-19-2015)
Old 02-19-2015, 01:10 PM   #5
47_47's Avatar
Rewards Points: 320
Have you considered getting a 3/8" drive torque wrench, with a range between 10 and 70? Of mine, I use my 3/8" the most, then my 1/4" inch pound and my 1/2" the least.
47_47 is offline   Reply With Quote
Old 02-19-2015, 01:32 PM   #6
Low Slope Roofing
Rewards Points: 114
No worry your tools do as you please. I agree with good tools, 95% of my hand tools are Snap On. The 1/2" drive torque wrench was around $200 when I got it. My son used it as a hammer once, case didn't save it then!
Old 02-19-2015, 02:12 PM   #7
Solidify's Avatar
Rewards Points: 834
I need the 1/2" because the only application I will be using the wrench for is to tighten the lug nuts on my car tires, and the range doesn't reach with anything smaller.
Old 02-20-2015, 07:49 AM   #8
78Vette's Avatar
Rewards Points: 580
Whats more important then a case is that you unwind the wrench before you put it away till your next tire swap. Forget about the pretty case.
78Vette is offline   Reply With Quote
The Following 3 Users Say Thank You to 78Vette For This Useful Post:
jomama45 (02-20-2015), NickTheGreat (02-20-2015), Thurman (02-23-2015)
Old 02-20-2015, 09:04 AM   #9
Solidify's Avatar
Rewards Points: 834
I already had the good practice of doing that 78Vette, thanks. I just bought the new wrench. It's so pretty. Either way, I find it odd that most of the torque wrenches I've seen in stores have always been packaged at torque settings higher than zero. I've even heard of some instances where people bought their wrenches and then opened 'em up to unwind them down to 0 and then the wrench no longer fit in the casing.
Old 02-20-2015, 09:14 AM   #10
78Vette's Avatar
Rewards Points: 580
I have several torque wrenches, and the ones that came in a case, do not have that issue of not fitting at 0
Old 02-20-2015, 12:59 PM   #11
Low Slope Roofing
Rewards Points: 114
Any of the ones I've come across have never had a problem fitting when the were turned down to the lowest setting. My 1/2" only goes down to 50 though.
Old 02-20-2015, 01:16 PM   #12
Solidify's Avatar
Rewards Points: 834
Why won't it go any lower than 50? Is that the limit of its range?
Old 02-20-2015, 02:21 PM   #13
Low Slope Roofing
Rewards Points: 114
50-250 1/2" drive.
https://store.snapon.com/US-Torque-I...e-P640963.aspx
Old 02-20-2015, 02:31 PM   #14
Solidify's Avatar
Rewards Points: 834
That's weird, I just bought the Mastercraft Maximum 1/2-in Drive Torque Wrench and it too says:
Maximum Ĺ" Drive Torque Wrench, with 50-250 ft-lbs (33.9-345.7 Nm) torque setting
and yet, I can bring the dial all the way down to 0 when storing it.
Old 02-20-2015, 03:54 PM   #15
Low Slope Roofing
Rewards Points: 114
No zero on mine, just the lowest setting.
Skill saw case rsteve12 General DIY Discussions 14 11-02-2011 05:37 PM
Torque and Temperature hunterthompson Electrical 2 12-14-2009 02:35 PM
Help with Impact and Ratchet Air Wrench Comparison, Confusing Specs donít match caliskier Tools 5 03-15-2009 10:33 PM
what wrench for a radiator fitting drewhart HVAC 9 01-07-2009 04:04 PM
spud wrench problem drewhart HVAC 3 01-06-2009 08:41 PM
