Spark Plug In Very Old Lawn Mower - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree1Likes
  • 1 Post By Rough Rooster
Old 07-27-2020, 09:38 PM   #1
Rewards Points: 6
Unhappy
Spark plug in very old lawn mower
So i am trying to help a neighbor that picked up a very old mower from a relative. The spark plug does not have a rubber boot, but has a sort of clip where the wire connects to the plug, and i cant seem to pull it straight off the plug without maybe damaging it. Is there a bit of a trick to remove that spark plug wire?
Jonijumpup is offline   Reply With Quote
Old 07-27-2020, 09:51 PM   #2
Rough Rooster's Avatar
Rewards Points: 456
Re: Spark plug in very old lawn mower
If that mower is really old there is a good chance the top of spark plug is a threaded stud with the wire loop placed on the stud and a threaded nut screwed down on it. See if there is knurling on the top of the spark plug metal part. If it as I suspect just simply unscrew the nut and remove wire.
RR
DexterII likes this.
Rough Rooster is online now   Reply With Quote
Old 07-28-2020, 08:06 AM   #3
Rewards Points: 872
Wow Rooster, I'm impressed! You're right, could very well be the case, but I haven't seen one of those in a long time, maybe at an auction and didn't pay that much attention to it, but sure wouldn't have considered the possibility.
Old 07-28-2020, 10:18 AM   #4
Oso954's Avatar
Rewards Points: 2,072
Other than a few specialty plugs, I don’t think I’ve ever seen a spark plug without the threaded stud on top. That push-on terminal that comes on the plug will usually unscrew to reveal the threaded stud. ( I know some solid posts are made, just don't recall running into them)
I’ve seen some people just use the Push-on terminal as a nut to hold eye terminals on, but it better to replace them either with a Hex nut or knurled thumb nut.
Oso954 is offline   Reply With Quote
Old 07-28-2020, 10:42 AM   #5
Rewards Points: 7,028
Some form of straight and 90 push/pull plug wire ends have been around for a few decades. Sometimes need a little persuasion.
According to NGK some plug terminal ends are removable ( threaded ) and some aren't.
Old 07-28-2020, 11:40 AM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 2,192
If it's really old there might be a metal grounding tab right near the plug - that was the only way to shut them off.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 07-30-2020, 08:19 PM   #7
Rewards Points: 6
Sorry guys, got held up a few days, here is a photo of the spark plug in question. Oops, I cant figure out how to attach a photo. Wont allow me to copy and paste. Photo helps me, could not see it that clearly otherwise. Looks like a small clip holding the wire on the end of the plug. Sort of locks it on. How do i get it off without damaging it?
Old 07-30-2020, 10:25 PM   #8
Rewards Points: 872
If it's what I'm thinking, you're going to unthread the tip of the tip of the plug, above where the wire is attached, like Rooster described. It might look like all one piece, and it might be on pretty snug, especially if it's been setting for a long time, but put a pair of pliers on it and I think it's going to come loose for you.
Tags
old lawn mower
