Putting Engine Back In - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree58Likes
Old 12-31-2019, 12:35 AM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 510
Finally got the engine ready to go back in. There have been all kind of things that made this build hard as the dickens. Then I am really slow and can't work on it long at a time so it really drags on. I have another problem, I am at the point of putting the 6 speed stick transmission on the engine so I can drop it in the car. As usual there is nothing standard on this car at all.
I can not find a clutch aligning tool so I can get the clutch plate lined up perfect. I have looked everywhere and can't find one. I may have to make one, I sure hope not. There is no tip on the end of this pilot shaft as there is no bearing or bushing in the crank. The whole shaft goes into the crank and it has a round flat end about the size of a quarter.
The pilot shaft is 23 mm in dia and has 21 teeth. I found one that is 25 mm and 23 teeth but that is as close as it gets. I don't know if this is a SE R Spec V transmission or a blame Altima transmission. I guess I need to find that out some way. I would sure like to tell that fellow a thing or two that I bought this dern car from. Any one have any suggestions short of making an alignment tool myself.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-31-2019, 01:15 AM   #2
retired framer
Rewards Points: 4,674
Re: Putting Engine Back In
@BigJim
You don't have a lathe , wood or metal by chance do you?
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 12-31-2019, 01:28 AM   #3
retired framer
So if the pilot shaft and the small of the spline are the same size can you just find a deep socket that fits inside both.
Old 12-31-2019, 01:59 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 510
Neal, I do have a lathe and am eyeballin a stick of bass wood. It is pretty soft so I may be able to drive it through the clutch plate and make an alignment tool.
The socket wouldn't work, the outside diameter of the shaft and the socket being the same size and there would be no way to get it in. I do appreciate you helping to think this problem out.
I even thought about drilling a pretty good size hole in the bell housing, put the clutch plate and pressure plate in as loose as I could. Stick the transmission in the plate and work it on in, then tighten the pressure plate up after I got it all in place. What bothers me there is that hole would let trash in and mess things up big time. I may go ahead and try to make one, if I can't find one.
Jim
Old 12-31-2019, 02:19 AM   #5
retired framer
The part that goes in the engine has to be the same as or smaller than the smaller measurement of the clutch or the trans shaft would not go thru the clutch
Once you have the clutch in just tight enough you can rotate the engine and measure in to the side of the plate from the outer edge of the flywheel.
Old 12-31-2019, 08:29 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,934
Ayuh,.... You shouldn't need the splines on the alignment bar,......
Just the small diameter of the spline hole,.....
Mike Milam likes this.
Bondo is online now   Reply With Quote
Old 12-31-2019, 09:06 AM   #7
Rewards Points: 1,824
Problem is that the hole for the pilot bearing is smaller than the hole for the clutch disc.
huesmann is online now   Reply With Quote
Old 12-31-2019, 09:11 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 510
Here is a photo of the pilot shaft. I dreamed about this last night, I may be able to turn a tool for aligning out of oak or hickory and make it work. See the shaft in the photo, the hole in the crank is the same size as the outside diameter of the teeth or the splines.
Jim
Old 12-31-2019, 09:21 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 510
There is no bearing or bushing in this crank, there wasn't one in the old crank. Here is a photo of the old crank:
See the hole, it is the same size as the outside diameter of the outer splines on the shaft. If you look close there is an indention in the very bottom of the crank about the size of a quarter and it is indented the same depth as the little tip is on the pilot shaft.
That first hole is for a bushing for an automatic transmission, that was a real bear to get out also, I had to cut it out.
Jim
Old 12-31-2019, 09:27 AM   #10
retired framer
Old 12-31-2019, 09:39 AM   #11
Huh. Looking at clutch kits for those cars, they don't have PBs. Weird. How do they keep the nose of the Tx input shaft centered on the crank?
Old 12-31-2019, 09:39 AM   #12
retired framer
Jim, you need a bushing.
Old 12-31-2019, 10:02 AM   #13
retired framer
Is it the same engine in an Altima This kit come with a bushing.
https://www.carid.com/2008-nissan-al...parentsubmodel[]=TRANSMISSION|Standard+%28Manual%29
Old 12-31-2019, 10:18 AM   #14
retired framer
This kit for a sentra comes with a bushing
https://www.buyautoparts.com/buynow/52-40669_EY
Old 12-31-2019, 10:46 AM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 510
Neal, it does for a fact show a bushing. Now I am confused, I need to do some more checking to see if one will even fit in there. As rigged up as this engine has been, there is no telling what the dude did who put all of this together. There is for a fact no bushing in the old crank, I need to look in the new crank now and do some measuring to see if one will work or not. I am like my wife now, I really hate this car. lol I really walked into it on this one for sure.
I also have to put new ball joints in after the engine is in, so much fun. I did tell my wife a year or so ago I would really like to rebuild one more engine. I sure wish I hadn't said that now. This car has broke me from suckin eggs. lol
Just had another thought, I don't have a clue what year this engine is. I do know for a fact that no Nissian engine below a 2007 will fit this car. The only one that will fit is the 2.5, the 2.0 will not fit.
Jim
