Nail In Tire....Side Wall? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree26Likes
Old 02-11-2020, 06:18 PM   #1
Rewards Points: 1,280
Nail in tire....Side wall?
Hello
My wife noticed an issue on her rear driver tire.....pressure was very low (sensor showing 14psi)
She took her car to the closest tire repair center which was a Walmart
They said it was a nail, but not repairable because on the sidewall....So I thought it was a nail into the flange
When I came back home, I took a look and saw the nail....is this really not repairable (nail is visible on the right side of the tire)?
french_guy is offline   Reply With Quote
Old 02-11-2020, 06:29 PM   #2
Re: Nail in tire....Side wall?
Although I have almost never been in a Walmart, twice I think, I have heard a number of people speak favorably of them, particularly in regard to tires. And sidewalls can be unforgiving on radials, but that doesn't look like a side wall to me. So I understand pricing, as well as loyalty, but unless I was ready to buy a new pair or set anyway I would stop by a Discount, Belle, or whatever you have and get a second opinion. Not that tires are anything I would gamble with, so I wouldn't be looking for the guy doing it in a back alley, but would want to see what a second legitimate party had to say before biting the bullet on a new one.
Old 02-11-2020, 06:44 PM   #3
Rewards Points: 3,734
I'll not be the judge.
https://www.tirerack.com/tires/tiret...jsp?techid=187
lenaitch likes this.
Old 02-11-2020, 06:46 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 280
Originally Posted by french_guy View Post
Hello
Ayuh,..... Go to a real Tire Shop,.....
That nail is clearly within the tread,......
Over the corner is the sidewall,......
Have 'em break the tire down, 'n do a patch repair on it, then remount, 'n balance if necessary,....
Old 02-11-2020, 06:48 PM   #5
Rewards Points: 1,128
Yank it out and put a plug in it.
Mystriss likes this.
Old Thomas is offline   Reply With Quote
Old 02-11-2020, 07:04 PM   #6
Should I go to a shop that does tire repairs all day long such as Belle Tire, or go to my dealership (Chrysler)?
Old 02-11-2020, 07:23 PM   #7
Rewards Points: 5,030
ajaye likes this.
ron45 is offline   Reply With Quote
Old 02-11-2020, 07:38 PM   #8
Rewards Points: 9,456
I have also heard that nail in the sidewall should not be repaired. It's just that, to me, a non expert, that nail does not look to be in the sidewall.
I would say its worth the trouble to get a second opinion.
SPS-1 is offline   Reply With Quote
Old 02-11-2020, 08:53 PM   #9
hkstroud's Avatar
Rewards Points: 6,416
I agree, that's what I would do. Or to be more accurate what I would have done. Shouldn't even have to take the tire off the car.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 02-11-2020, 10:03 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,626
Until just recently (when the hole was too large for a plug), I was like 15-0 in fixing tires with plugs. 15-1 ain't bad though.
raylo32, Bondo, Gymschu and 1 others like this.
Old 02-12-2020, 07:15 AM   #11
A pan head sheet metal screw works as a excellent plug until you get your SS check next month. She stays right there at 70 on the pike. If a guy forgets and the head wears off the tire shop has no problem getting it out when they remove the tire to fix it the traditional way.
Old 02-12-2020, 07:17 AM   #12
retired painter
Rewards Points: 1,880
Sure looks to me like it can be plugged or use a vulcanized patch on the inside [better]
Yrs ago I had a side wall puncture on a fairly new large 4x4 tire. I had a tube put in it so I could continue to use that tire.
SeniorSitizen likes this.
mark sr is offline   Reply With Quote
Old 02-12-2020, 09:51 AM   #13
What is that?
Brainbucket's Avatar
Rewards Points: 1,758
It's repairable.
Windows on Wash likes this.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 02-12-2020, 03:39 PM   #14
Mystriss's Avatar
Rewards Points: 4,942
https://www.amazon.com/dp/B000ET525K...ing=UTF8&psc=1
Isn't the best kit, you can find a decent "pro" kit for $20, but that's all they typically use to fix the tire in a shop. Only thing you lose is the warranty or whatever on the patch work if it fails. Husband patches nails and screws all the time due to 100 mile a day commute through housing construction zones and we've never had a single patch fail in 20-some years.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 02-12-2020, 04:47 PM   #15
Rewards Points: 7,603
Your pic shows the entry point of the nail and if it went straight I agree it should be repairable.
Did you verify that the tip did not exit in the real sidewall?
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
