Im Afraid To Start My Car - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree41Likes
Old 05-03-2019, 01:00 PM   #1
Rewards Points: 1,546
Im afraid to start my car
People,
Like I didnt have enough to do (head gasket 2001 Civic), driving to work this morning and 1987 Sunbird GT started producing a huge cloud of white smoke. Immediately pulled off to the side and shut off car. Under hood, I saw watery fluid (coolant) oozing from left front bottom corner of head. So I immediately guessed it blew the head gasket (sheesh, another one to do now).
AAA towed it home, but first he turned over the key to try to start it. I cant remember exactly what happened, but it wouldnt start, and he said "it seems frozen". He said, driving with him home, that the engine is shot, not worth rebuilding. How can I verify this? I dont want to try to turn over the car if I will do more damage (assuming it is in fact salvageable, and actually not "frozen".
Except for the people here, I dont trust completely advice given as I have proved even pros wrong in the past.
If head is blown and coolant introduced, could I remove plugs, purge out any coolant, try starting again? Hate to start it if I can damage more.
Thanks, people.
papereater is offline   Reply With Quote
Old 05-03-2019, 01:09 PM   #2
retired framer
Rewards Points: 14,094
Re: Im afraid to start my car
If you shut it off before it stopped you have a chance, water doesn't compress so if water is in the cylinder it won't turn over, but you might turn it it backward to prove it is not frozen Remove the plug and remove the water. The sooner you can open it up and clean the water out the better you don't want rust in there.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
papereater (05-03-2019)
Old 05-03-2019, 01:34 PM   #3
Rewards Points: 494
Agree with Neal. Pull the plugs and turn it over. The water should blow out. If it doesnít Turn over then I would say itís not looking good
papereater likes this.
BayouRunner is offline   Reply With Quote
The Following User Says Thank You to BayouRunner For This Useful Post:
Old 05-03-2019, 02:11 PM   #4
Gonna try that now.........
Old 05-03-2019, 04:05 PM   #5
Wow, this made my day....no, my year. The car spewed out coolant on that one cylinder which apparently, has the broken gasket portion. Coolant all over the front of the car, which I washed off immediately. It is not frozen! All it needs now is a head gasket. 2nd one in 31 years. Not so bad. Will get to this as soon as I finish the civic head gasket. Sheesh. Anyway, thanks for the advice.
Dave Sal likes this.
Old 05-03-2019, 04:14 PM   #6
retired framer
I would drain the water and put some oil in the there set up a rag to catch the mess and turn the engine over, You would like to get the water out. You may want to do that a few times. Once you are sure the water is out replace the plug. Oil might be contaminated too.
Old 05-03-2019, 04:23 PM   #7
Rewards Points: 494
Wd40 works good too.
de-nagorg and Nealtw like this.
Old 05-03-2019, 06:05 PM   #8
retired framer
We didn't have that when I worked on cars.
Old 05-03-2019, 06:27 PM   #9
Rewards Points: 494
Works on four wheelers too!
de-nagorg likes this.
Nealtw (05-03-2019)
Old 05-03-2019, 08:38 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 1,764
I was at my mechanic's shop a couple of years ago and he was working on a 'hydro-locked' engine and he had homemade nozzle made from some fittings and a length of brake line hooked up to his shop vac that he was using to suck out as much water as he could. Unless you are going to get at it right away, some light oil/WD40 down the plug hole after you have cranked out as much as you can should keep the rusting down (maybe more than once if it's going be a long time since it will likely leak down past old rings). Time for new oil and coolant, perhaps a couple of cycles.
Dave Sal and papereater like this.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
papereater (05-04-2019)
Old 05-03-2019, 09:18 PM   #11
JUSTA MEMBER
Rewards Points: 2,410
A tip from a pro, every time that you open up an engine, change the oil, coolant just to remove any potential damage from something that might have gotten in that don't belong.
Many modern auto-techs, won't bother changing the fluids, and in my opinion, are just Glorified Parts Changers, not mechanics.
Looks like you got the problem worked out, before I saw the post.
You have the rarest head gasket failure, but it does happen.
And a dose of WD-40, will protect the cylinder temporarily, but get it repaired ASAP.
WD-40 = Water Displacement formula # 40, from the inventor.
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
KaseyW (05-10-2019)
Old 05-04-2019, 12:33 PM   #12
Thanks, people. Will try to get to this asap. Dont want a rusty engine. It will be messy, though. Lots of old towels........
Old 05-04-2019, 01:51 PM   #13
JUSTA MEMBER
You can usually buy a box of old clothes at the Salvation Army store, marked as rags.
For a $ or 2.
ED
Old 05-04-2019, 02:33 PM   #14
Oso954's Avatar
Rewards Points: 1,326
I donít turn engines over with the starter when I suspect hydro lock. It may not be a problem with small displacement engines, but with large displacement engines the water (or oil) may not squirt out the spark plug hole fast enough. You can crack the head, bend connecting rods, or otherwise damage the engine.
Ever see a WWII film of a line of guys hand pushing the props through blade by blade on a bomber ? They are making sure that a lot of oil hasnít drained down past the piston rings on the lower cylinders of those radial engines.
Because of the 4 blades and the gear reduction, they had to pull 16 or more blades through to get 2 full revolutions of the crank (on each engine). Turning most car engines 2 revolutions of the crank is much easier.
lenaitch likes this.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
papereater (05-05-2019)
Old 05-04-2019, 02:49 PM   #15
Usually Confused
lenaitch's Avatar
Cool!. I was never sure why they did that 9I thought they were pre-circulating oil or priming the engine or something. Thanks!
Oso954 likes this.
Who Dares Wins
John Deere Z425 2007 hard start rickluc Tractors & Mowers 8 09-21-2017 05:09 PM
dryer doesn't start, sometimes ratherbefishing Appliances 1 03-06-2016 08:52 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
