I Don't Want My Van To Rust ! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree15Likes
Old 05-12-2019, 04:16 PM   #1
dd57chevy's Avatar
Rewards Points: 2,630
I don't want my van to rust !
The transmission on my work van (2000 chevy 2500 express cargo) failed . This vehicle has a lot of miles & MAJOR rust on rocker panels & door bottoms . It's embarrassing !
I decided to look around & found an '05 that runs well & has a remarkably clean body , especially for Iowa . There IS frame rust , but just minor rust starting on rockers & inside the doors .
I pulled the door panels & the plastic foot wells (where you step into van) & washed out a lot of dirt .
OK , here's my question (don't laugh) :
I know a lot of you guys use "Fluid Film"....but how about spray white lithium grease ? It's 1/3rd the price of FF & would stop rust .
.why not ?
dd57chevy is offline   Reply With Quote
Old 05-12-2019, 05:00 PM   #2
HenryMac's Avatar
Rewards Points: 892
Re: I don't want my van to rust !
Grease stops rust?
Grease will collect a lot of dirt and filth, and if there are drain slots in the panels (there almost always are) the grease will plug those and the panel will hold water.
Dave Sal and de-nagorg like this.
HenryMac is offline   Reply With Quote
Old 05-12-2019, 09:24 PM   #3
JUSTA MEMBER
Rewards Points: 3,032
Here they get "RHINO LINING" to coat about a foot of the lower rocker panel, and fenders.
To prevent premature body rust.
Makes for a two tone finish, and looks Customized.
ED
de-nagorg is online now   Reply With Quote
Old 05-12-2019, 10:44 PM   #4
dd57chevy's Avatar
Originally Posted by HenryMac View Post
Grease stops rust?
Certainly grease stops rust !
In order for metal to oxidize , you need moisture & air . Grease , any kind of grease , whether petroleum based or lanolin based seals it out . That's 7th grade science .
Take a rusty bolt , coat it in grease , then set it out in the elements this summer . It won't rust anymore !
Thinned out grease probably would take longer to shed liquid to become stabile . And would collect more dirt in the process . But unless it was applied in extreme heat , I'm not sure it would migrate & somehow solidify & plug weep holes .
Does FF just dry faster , is that the advantage ?
mark sr likes this.
Old 05-13-2019, 12:47 AM   #5
Rewards Points: 4,026
I don't know, dude. Road salt eats metal so unless you move considerably further south, I don't think the result is going to be worth the effort.
stick\shift is offline   Reply With Quote
Old 05-13-2019, 04:45 AM   #6
retired painter
Rewards Points: 904
The quicker and more often you rinse off the salt the better! Not just the body but under the vehicle also. Most folks wash their vehicle less in the winter but when salt is used it needs washing more often.
de-nagorg likes this.
mark sr is offline   Reply With Quote
Old 05-13-2019, 09:48 AM   #7
dd57chevy's Avatar
I'm not claiming to be an expert , but an old science teacher told us that salt makes water wetter..... In other words , it breaks it down & makes it penetrate further . Don't know if that is true.....
But I'm pretty sure some kind of grease that seals the metal will protect it . Yea , areas that get heavy rain wash (wheel wells , for instance) , would need to be re-coated , but that could be done .
ANYWAY , I've watched the FF videos on YouTube , but was hoping someone could get any advantages of it through my thick head !
I'll probably buy an aerosol can of FF today & give it a whirl .
Old 05-13-2019, 10:11 AM   #8
JUSTA MEMBER
I realize that you are seeking a fast easy preventative.
But the best way that I ever found to keep the body of a daily driver rust free was to wash and paste wax it, at least weekly.
No one has the time, nor do they care to paste wax them anymore.
But have you ever seen an in service FIRETRUCK that was rusted?
No, they wash and WAX it every trip out of the firehouse.
ED
Old 05-13-2019, 10:12 AM   #9
Rewards Points: 1,897
First you want to remove any rust that's actually there, because rust never sleeps. There's no point in rust prevention if you're leaving any rust in place.
Krown? Zeibart? Waxoyl?
huesmann is offline   Reply With Quote
Old 05-13-2019, 11:05 AM   #10
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,802
The problem with using an alternative to FF is that it may cause the rubber parts to swell.
FF doesn't dry and will need to be re-coated once/year for cars in the salt belt. Since it doesn't dry it won't block any drainage holes but it gets slowly washed off over the course of the year.
I bought a new truck a few months ago and the first thing I did ahead of winter is coat the undercarriage with FF. I bought the gallon size and spray gun. I used about 1.5 quarts to cover everything but I got inside all the holes down there.
Dave Sal, de-nagorg and dd57chevy like this.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-13-2019, 11:17 AM   #11
Dave Sal's Avatar
Rewards Points: 958
Just before last winter I was installing my winter wheels and noticed a small bit of surface rust on a few areas of the undercarriage. Got my can of Fluid Film, used fine steel wool to remove the rust and sprayed the areas with a coating of FF. When I mounted the summer wheels about a month ago the FF was still there doing it's job with no evidence of rust. This has become my annual anti-rust ritual.
Bondo and de-nagorg like this.
Dave Sal is online now   Reply With Quote
Old 05-13-2019, 04:58 PM   #12
dd57chevy's Avatar
Look , I'm not deliberately trying to beat this into the ground , but other than FF might look better , I still don't see the difference .
An FF video I watched suggested NOT soaking rubber (CV boots , seals etc.)
& if it doesn't dry , then it IS basically a grease .
Old 05-14-2019, 08:09 AM   #13
I have gas!
Exactly, it's an oil. Lanolin oil to be exact. Supposed to be environmentally friendly too.
I've got a friend who uses used motor oil. Same concept but you absolutely need to absolutely stay clear of rubber parts.
dd57chevy likes this.
Old 05-19-2019, 12:16 PM   #14
Rewards Points: 4,072
I heard and read the reviews and plan to try this one myself.
Read the reviews and see some pictures.
https://www.homedepot.com/p/Corrosea...2320/202960538
ron45 is offline   Reply With Quote
Old 05-19-2019, 12:22 PM   #15
I used this and got good results.
But heard that the corroseal works better.
https://www.amazon.com/VHT-SP229-Rus...ateway&sr=8-12
Had a VW bug and the floors were a nightmare.
I cut out and sanded all areas then painted.
I then added aluminum sheets to the bottom of the floor boards with aluminum pop rivots.
I bought the panels from here.
https://www.jcwhitney.com/?TID=gglse...E&gclsrc=aw.ds
Example.
Rust and rust and rust and rust and rust and rust and rust and more rust, etc. DoomsDave Automotive Repairs 3 03-17-2019 04:51 AM
How To Remove Rust Stains - Rust from Tools Flannel Guy DIY How To Guides 2 05-30-2017 02:15 PM
Rust converter (phosphoric acid) not working Studly Automotive Repairs 3 05-02-2013 06:57 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 06:28 PM
