EVCV Or EGR Solenoid? Or Neither..? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree7Likes
  • 2 Post By ChuckF.
  • 1 Post By ChuckF.
  • 1 Post By Brainbucket
  • 1 Post By ChuckF.
Old 06-20-2016, 08:32 PM   #1
4t7
Rewards Points: 12
EVCV or EGR solenoid? Or neither..?
Trying to figure what the proper name of this part is...it's mounted on same bracket as the MAP(?) sensor. Has a vacuum line that runs down to EGR valve and another intake port. Is this thing called an EVCV(electronic vacuum control valve)? Or is it an EGR solenoid..?
I searched for the part and got many results for other makes/models but not for mine...vehicle is a 95' chevy G20 with 5.7l 350 in it. Is it perhaps known by another name on this model?
Also, where are some good places to buy auto parts online? I'm pretty sick of going to the local parts stores
4t7 is offline   Reply With Quote
Old 06-20-2016, 09:48 PM   #2
Rewards Points: 1,906
Re: EVCV or EGR solenoid? Or neither..?
Rockauto has great service and prices. Is it the Vapor Canister Purge Valve perhaps?
http://www.rockauto.com/en/catalog/c...+solenoid,4936
r0ckstarr and 4t7 like this.
ChuckF. is online now   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
4t7 (06-22-2016)
Old 06-20-2016, 10:03 PM   #3
4t7
Rewards Points: 12
Thanks for the suggestion. Had heard about RA before...looks pretty good.
As far as it being VCPV...idk if thats the right part. It does look really similar though...maybe the part has been slightly redesigned/upgraded and looks different?
Old 06-20-2016, 11:21 PM   #4
Possibly; maybe the one on your vehicle is something someone substituted. Confirm the number of ports, some of them have three, most have two.
You have to find a picture of the EGR/emissions circuit layout on your vehicle, that's the only sure way to ID the part.
4t7 likes this.
4t7 (06-22-2016)
Old 06-21-2016, 09:32 AM   #5
What is that?
Brainbucket's Avatar
Rewards Points: 1,758
If memory serves me correct, (there is snow on da roof)it is an EGR solenoid.
4t7 likes this.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 06-21-2016, 05:04 PM   #6
4t7
Rewards Points: 12
It has 2 ports on backside (one of which is an intake port) and one more port on it's front. Top port on backside has vac line that runs to egr valve. Bottom port on backside is an intake port(?)
Old 06-21-2016, 05:10 PM   #7
4t7
Rewards Points: 12
hahah, @Brainbucket . That's what I thought it was called but still can't seem to find a relacenent part called an 'EGR solenoid' for a 95' chevy 5.7l 350. Autoparts store wasn't very helpful either.
Old 06-21-2016, 07:50 PM   #8
EGR Valve Control Solenoid: http://www.rockauto.com/en/catalog/c...d+/+motor,4380
The search engines at car parts stores and websites are very unsophisticated. If you went back and asked for an "EGR valve control solenoid" they would probably find it. Typically to find something like this I would just search for "EGR" and look through all the hits.
4t7 likes this.
4t7 (06-22-2016)
Old 06-22-2016, 02:35 AM   #9
4t7
Rewards Points: 12
You're an angel and a godsend @ChuckF I apprecatiate you taking the time to help a fellow man in need out. I really do. Thank you!
Old 06-22-2016, 09:08 AM   #10
What is that?
EGR Control solenoid from NAPA
The port with the foam on it is the breather to release vacuum. This is for a 95 Chevy G20 van with a 5.7 part # CRB 219225
4t7 likes this.
Old 06-22-2016, 06:20 PM   #11
4t7
Rewards Points: 12
Thank ye kindly, good sir @Brainbucket .
Just placed my order a couple hours ago. Says it should be here by friday...Here's to hoping this part gets my van back on the road. A mans gotta dream, right?
Thanks everybody!
Old 06-23-2016, 09:12 AM   #12
What is that?
What is it doing? Vacuum is at EGR all the time keeping it open and van running bad or dieing? If so, just unplug the EGR and plug the vac hose or plug the port that the EGR solenoid is getting vac from. It should run fine just gas mileage will be down some.
4t7 likes this.
The Following User Says Thank You to Brainbucket For This Useful Post:
4t7 (06-27-2016)
Old 06-27-2016, 11:58 PM   #13
4t7
Rewards Points: 12
Just running extremely poorly under load. It's fine at idle. Yeah, the vac was at egr. I did unplug it and that makes the van run a little better but it still has lack of power. Doing this is what led me to suspect the EGR control solenoid was bad. I installed the new one today and it made little to no difference. I mean it can still drive around (kinda, lol) and whatnot but I won't/can't take it on the road like this. Way too many hills in NC for that...
Beginning to suspect MAP sensor or possibly worn out valves/rings which had been suggested to me two times today. Don't think I'll be moving forward on any repairs without checking engine compression first...
Old 06-29-2016, 10:22 AM   #14
What is that?
Timing, EGR 'flutter'( EGR spring is weak and lets the EGR open to soon), Fuel pressure, of course compression, restricted exhaust. If you unplug MAP it should run extremely rich. Check engine light on? O2 sensor is a one wire O2. Unplug it and does do anything? Read codes before you create them. Get a timing light and look at the spray pattern of the fuel injectors. One might not be spraying as much as the other one.
Old 06-30-2016, 11:41 PM   #15
4t7
Rewards Points: 12
Timing- Will have to look into how to check this as I haven't checked yet.
EGR spring- appears ok; spring is still very strong.
Fuel pressure - I don't believe this is the issue. Brand new fuel pump and filter installed. However, have not checked the fuel pressure regulator...
compression - have not checked yet. At top of my to-do list
restricted exhaust - have not checked yet. Have to figure out how...Advice? 🍻
unplug MAP - will check tomorrow...
NO check engine lights on at all...seems unusual. Fried computer perhaps?
Unplug 02 - tried this a while back. Little to no difference 😞
Timing light - have no clue how to do this...YOUTUBE here I come! 😵
Thanks as usual Brainbucket. You been alot of help good sir!
Solenoid for Honeywell HE225a humidifier Toller HVAC 4 12-04-2014 04:10 PM
Rapid cycling of humidifier solenoid valve MI-Roger HVAC 2 10-28-2011 10:31 PM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 05:26 PM
Noisy solenoid chatter and compressor won't kick in now David H10 HVAC 53 08-28-2009 08:43 PM
