AC Clutch Plate Removal - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-28-2020, 09:26 AM   #1
Rewards Points: 1,996
AC clutch plate removal
People,
Impossible to remove my 2001 civic ac compressor clutch plate. I removed the 14mm nut, exposing a splined shaft. Because some plates have bolts, one can insert a special extraction "bolt", but mine does not have a bolt, just a nut. How does one remove the plate? I tried prying gently along the outer side circle of the plate but hesitate to pry too much as one can warp the plate, right?
What do I do, people?
papereater is offline   Reply With Quote
Old 06-28-2020, 10:59 AM   #2
Rewards Points: 6,378
Re: AC clutch plate removal
Have you watched clutch plate removal videos?
SeniorSitizen is offline   Reply With Quote
Old 06-28-2020, 11:41 AM   #3
Rough Rooster's Avatar
Rewards Points: 452
Get the special plate puller tool for your particular compressor.
Any other attempts to remove plate will destroy components and make the job much more costly than the tool.
Been there -- done that!
RR
Rough Rooster is offline   Reply With Quote
The Following User Says Thank You to Rough Rooster For This Useful Post:
papereater (06-28-2020)
Old 06-28-2020, 11:49 AM   #4
None available. Searched all over.
Old 06-28-2020, 12:30 PM   #5
Rewards Points: 1,030
I didn't watch it because I'm not interested but it may be of value to you .
https://www.google.com/search?q=to+r...G3ggfw4ZaADg28
Porsche986S is offline   Reply With Quote
Old 06-28-2020, 12:38 PM   #6
ukrkoz's Avatar
Rewards Points: 1,496
You most likely have spring lock. It is hidden inside the clutch, on shaft. If that's the case, you will need special tipped pliers, angled to 90 degrees, to reach inside to compress the spring.. Do not go cheap on them, when buying. I had set of cheap ones, after 2 hrs of struggling to remove locking spring, I bought better tool and had job done in 5 minutes.
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
papereater (06-29-2020)
Old 06-28-2020, 12:53 PM   #7
If ya get in a bind for snap ring plier tips and sizes / angles, as a DIY'er you can make good straight and 90 tips from those old extra Allen wrenches.
Old 06-28-2020, 03:25 PM   #8
Rewards Points: 1,262
I don't know about your Honda, but the couple vehicles of that age that I've worked on the A/C for, the clutch wasn't available because it wasn't removable without taking the compressor apart. If you are able to find a replacement clutch, yours may be different.
If possible, I suggest visiting one of those pull-it-yourself junkyards and experiment with removing one off of a junked vehicle, before you get tto aggressive with yours.
HotRodx10 is offline   Reply With Quote
The Following User Says Thank You to HotRodx10 For This Useful Post:
Old 06-29-2020, 12:26 PM   #9
Wow- soo helpful! Why didnt I find that?!! Thanks, porche! But I have to mention - he got lucky- his plate popped off just by the touch of his fingers. Mine I had to pry/jiggle/tap, etc. Finally came off.
Old 06-29-2020, 12:30 PM   #10
Found a site that supplies a clutch/plate kit. Will buy that one and use just the plate for now- no need to yank the tedious clutch for now. My plate has about 1/2 of the circumference of the grabbing area worn down to the bone. Glad I did this instead of suspecting the compressor, at least for now, seems it's the fault of the clutch plate.
Old 06-29-2020, 12:32 PM   #11
My year (2001) is still available, but as a complete clutch kit. Why dont they sell just the plate if one only needs that? Sheesh. Couldnt fine one anywhere (separately, that is).
Old 06-29-2020, 02:58 PM   #12
It's funny as it was the first one I found when doing a generic search . I hope it was helpful and good luck with your repair .
Old 06-29-2020, 03:12 PM   #13
Hey, consider yourself lucky; my only option was to replace the compressor, so I had to buy a vacuum pump to draw it down, and then recharge it, on top of the cost of the compressor.
Old 06-30-2020, 05:42 AM   #14
Rewards Points: 2
Nice. Thx!!
sahrenity is offline   Reply With Quote
