2012 Tacoma Brak Noise - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree2Likes
  • 1 Post By mark sr
  • 1 Post By Brainbucket
Old 07-09-2019, 02:15 PM   #1
Rewards Points: 12
2012 Tacoma brak noise
I put new pads on the rear 12 Tacoma drums. It squeaks, The noise is a loud sound like your hand slipping on a wet glass door but much louder. I did not grease the touch points on the pads where it hits the side of the break housing. I can do that but am not sure this is what is going on. It seems worse when I am backing up then going forward. Also its only when I apply the breaks light and goes away when I press harder. I am wondering if I did not adjust the breaks correctly and they need to be adjusted out more.
edteach is offline   Reply With Quote
Old 07-09-2019, 02:27 PM   #2
retired painter
Rewards Points: 858
Re: 2012 Tacoma brak noise
I'd jack it up and remove the wheel and drum. I'd suspect something is dragging - maybe a spring.
mark sr is online now   Reply With Quote
Old 07-09-2019, 02:48 PM   #3
JUSTA MEMBER
Rewards Points: 2,964
I'd look for a binding Emergency Brake Cable.
Sometimes the thing won't release properly, and causes this annoyance.
ED
de-nagorg is offline   Reply With Quote
Old 07-09-2019, 04:00 PM   #4
Bigplanz's Avatar
Rewards Points: 2,254
Since I got my Navigator with rear disc brakes, I will never own a car with drum brakes again.
"The first time you do a repair on your car, it takes 4 hours, minimum. The second time, 1/2 an hour. There never is a second time, though."
Bigplanz is online now   Reply With Quote
Old 07-10-2019, 08:52 AM   #5
Rewards Points: 1,861
Some cars have rear disc brakes that use a drum (the rotor "hat") for the parking brakes.
huesmann is online now   Reply With Quote
Old 07-10-2019, 09:50 AM   #6
Bigplanz's Avatar
Yeah, "drum in hat." My Navigator uses that design. Many orders of magnitude simplier to install and adjust than a drum brake, though. Plus, most people never even use their e-brake, so they never wear out. Last time I set my e-brake was because I was curious if it even worked. It didn't.
Old 07-10-2019, 10:01 AM   #7
What is that?
Brainbucket's Avatar
Rewards Points: 1,592
Cheap pads will sometimes do that. Brake dust will add to it. Put some brake anti-squeak ointment on back and sides where it makes contact with the caliper bracket ie pad holder. If it doesn't stop, upgrade your pads to OE Pads.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 07-10-2019, 10:08 AM   #8
Bigplanz's Avatar
He said he has drum brakes in the rear.
Old 07-10-2019, 10:32 AM   #9
raylo32's Avatar
Rewards Points: 686
Can't really help here but a question: I have a Tacoma with 86k miles. How many miles on yours to need new rear brake shoes? On my previous truck (Chevy S10) with drum rear they never needed replacing.... sold it with 110k miles.
Yes, BP, I am with you. For whatever reason Toyota burdens these otherwise great little trucks with rear drums. I hate them, too.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-10-2019, 11:33 AM   #10
retired painter
Rewards Points: 858
My jeep has that type of e-brake. My son's friend had a similar jeep and had to replace those tiny shoes - said it was a real pain to do. Personally I prefer drum brakes in the rear. Seems like when pulling a heavy trailer without brakes it's easier to slow/stop with drum brakes than with all discs.
ron45 likes this.
Old 07-10-2019, 02:59 PM   #11
What is that?
I went by the PAD statement. Looked it up. It's shoes. Now I know what's going on. He didn't clean the brake dust out of the drum and/or the backing plate. It's the brake dust that's causing the noise. Remove drum, spray it down with brake clean and the shoes/backing plate as well. Reinstall and adjust.
de-nagorg likes this.
Old 07-11-2019, 07:55 AM   #12
Originally Posted by bigplanz View Post
plus, most people with automatic transmissions never even use their e-brake
ftfy.
