Smoke Detector Drive Me Crazy - Safety - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Like Tree27Likes
Old 02-11-2020, 11:13 PM   #16
Rewards Points: 1,924
Re: Smoke detector drive me crazy
Current ones are about 6 months old.
Iíve been reading the Fla building code.
Nik333 likes this.
Startingover is offline   Reply With Quote
Old 02-12-2020, 07:30 AM   #17
Rewards Points: 8,174
I can offer moral support but no help. Getting ready to replace ALL of mine.
Bud
Startingover likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 02-12-2020, 04:27 PM   #18
raylo32's Avatar
Rewards Points: 1,288
Around here the new code call for models with the 10 year lithium batteries. These will be nice to have and avoid the routine battery replacements.... especially if you have one like mine that is ridiculously high on a stairwell ceiling. Always an adventure up there to change a battery or detector.
Startingover and Nik333 like this.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 02-12-2020, 10:59 PM   #19
Rewards Points: 850
These units, at least the ones made for kidde are complete garbage.
I've experienced first hand - defective and constantly going off.
The reviews are horrible - many are defective and have false alarms and batteries dying prematurely.
The concept is bad - ordinary alarms can work just fine beyond 10 years, they just need to be tested regularly. With the sealed lithium unit, you're forced to throw it away after 10 years.
I'm betting the manufacturers lobbied for requiring a non-replaceable battery to create an ongoing market.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 02-13-2020, 01:38 AM   #20
Rewards Points: 2,754
It is a requirement in most jurisdictions that any and all smoke alarms be replaced after 10 years.
FrodoOne is offline   Reply With Quote
Old 02-14-2020, 01:11 AM   #21
Rewards Points: 850
As long as it's not enforced, who cares?
Corporations lobby for laws - in the worst case they practically write building codes to ensure use of their products.
Old 02-14-2020, 10:44 AM   #22
Rewards Points: 653
Many years ago, I learned that ionization detectors were more sensitive to ambient conditions and would alarm when nothing was burning. This would occur when there was a rapid change in humidity. I seen this happen at a hospital when someone would open a door to the laundry room. The hospital switched over to photoelectric detectors and the false alarms stopped.
Now whether this holds true today, I do not know.
However Manufacturers have had plenty of time to correct the faults of both types. There is a differance on how both operate. A photoelectric smoke detector will alarm when there is visable smoke whereas a ioniztion detector will alarm when it detects the invisable products of combustion called ions.
Here's what I would do to correct the problem.
1. Identify all detectors as to type.
2. Make sure the detectors are not a dual type that also detects carbon monoxide. Your better off having carbon monoxide detectors as a separate alarm.
3.Take more pictures of your detectors and list distances to any source of combustion. Especially the one thats above the ac intake.
4 All your detectors should be of the same manufacturer.
5. Part numbers should be the same on all photoelectrics.
6. Part numbers should be the same on all ionization detectors.
Email the manufacturer with your pictures and explain the problem.
My initial guess that you have ionization detectors in areas where
they should not be.
rjordan393 is offline   Reply With Quote
Old 02-14-2020, 12:46 PM   #23
Rewards Points: 850
ionization alarms still have all the same flaws they did back when they were new technology.
used alone without photo electric, they provide a false sense of security since smoldering fires don't produce enough invisible products of combustion in the smoke to be detected until it's too late.
they're still made only because they're cheap to produce.
Startingover and FrodoOne like this.
Old 02-18-2020, 01:01 PM   #24
Rewards Points: 252
just a throw in from me,
we had an electric stove and we never had any problems, went gas and then the alarm went off regardless, we changed the extractor to a more powerful one no joy, then changed the smoke detectors out.
can't rmember which way round, ionizer to PE or vice versa, that did the trick,
now if the alarm goes off, theres a reason behind it ! LOL
HTH
ajaye is offline   Reply With Quote
Old 02-19-2020, 10:18 PM   #25
I learned something when working. Donít spray anything on smoke detectors. Had a fly in my office. Tried spraying with bug spray. It flew out into the hall with me following. It landed on a ceiling Smoke Detector and I sprayed it and immediately a red light came on and I thought Ďoh crapí. Yes a big fire truck came but I met them out in the drive and explained. I know they snickered.
Old 02-19-2020, 11:32 PM   #26
Rewards Points: 4
So these detectors are hooked up to some type of alarm that calls the fire department?
TrojanHorse is online now   Reply With Quote
Old 02-20-2020, 12:07 AM   #27
Evidently but that was a new Senior apartment building where I was property manager. The building also had a sprinkler system.
Nik333 likes this.
Old 02-20-2020, 12:15 AM   #28
Rewards Points: 1,582
For many years, hospital nurses would put blankets in the microwave to warm them. Until one day the blanket started to smoke, set off a smoke alarm & a Fire Truck came, big fine, That might have been the advent of blanket warmers.
Nik333 is online now   Reply With Quote
Old 02-20-2020, 01:10 AM   #29
Rewards Points: 3,734
Last week burned toast, there was a little smoke. Yes, SD went off.
A sure sign of a Black and Decker toaster.
Old 02-20-2020, 08:35 AM   #30
Nik, those heated blankets are absolutely wonderful. I’ve thrown an afghan in the dryer when I’ve gotten chilled.
I’m looking online for photoelectric SD. Most have the 10 yr battery.
In my garage I have a radioactive old SD laying around that said replace after 10 yrs so when I bought this house I took it down. But the Hazardous Waste place is out of the way an I never bothered to take it there. Yet.
Thanks everyone. I never would have known the difference in ‘I or P’ without your help.
