Smoke Detector Drive Me Crazy - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Like Tree27Likes
Old 02-09-2020, 09:25 PM   #1
Rewards Points: 1,864
Smoke detector drive me crazy
Just measured from stove, around the corner to short hall where my bedroom is. 12 ft.
The SD is on the ceiling and it GOES OFF ALL THE TIME.
Heating oil. A high burner. And my toaster is farther away. Maybe another 8í. Last week burned toast, there was a little smoke. Yes, SD went off.
I keep ear plugs handy when I cook now. Just turning ceiling fan on and opening a door an it goes off quickly.
What can I do?
A fireman installed it.
Startingover is offline   Reply With Quote
Old 02-09-2020, 09:37 PM   #2
Rewards Points: 4
Re: Smoke detector drive me crazy
What can I do?
Is it photoelectric or ionization? Ionization may work better there.
https://www.nfpa.org/Public-Educatio...-photoelectric
Startingover and ajaye like this.
TrojanHorse is online now   Reply With Quote
Old 02-09-2020, 09:43 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 728
What can I do?
Startin...Stop burning toast....
MTN REMODEL LLC is online now   Reply With Quote
Old 02-09-2020, 09:54 PM   #4
Rewards Points: 728
Starting...is there any reason any smoke would likely collect there...ventilation flow eyc....
I had a cathedral hip in our home kitchen..... I did have to move the the SD down a little.
Startingover and Nik333 like this.
Old 02-09-2020, 10:24 PM   #5
Rewards Points: 712
photoelectric is less prone to nuisance trips due to cooking smoke, actually.
ionization only alarms, in addition to going off from cooking too much don't provide adequate escape time when the smoke is from a smoldering fire.
Startingover likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 02-09-2020, 10:41 PM   #6
Rewards Points: 4
Youíre right, I was wrong in my previous post.
MTN REMODEL LLC and Nik333 like this.
Old 02-09-2020, 10:43 PM   #7
Louvered door on left in front is pantry. Stove is about 30” away from that. You can see the AC return air near the floor. On right.
If I take the SD down to inspect will it say which kind it is?
Old 02-09-2020, 11:14 PM   #8
Rewards Points: 4
Louvered door on left in front is pantry. Stove is about 30Ē away from that. You can see the AC return air near the floor. On right.
Attachment 585567
When you have time to put it back in (safety first!!) Iím sure it will show a model number at least which will be useful. Also you can tell if itís wired or wireless. If wireless you can move it, but maybe your firefighter friend can help with this problem on site
Old 02-10-2020, 12:04 AM   #9
Rewards Points: 712
Ionization alarms have a radioactive material warning on the back.
The newer alarms are marked with either a i or p on the front if not dual sensor.
The return may be pulling air from the kitchen into the hall increasing the risk of false trips.
A photoelectric alarm may still go off from cooking but not as early or frequently.
If you have a vented exhaust fan over your stove, use it.
If there's a range hood/exhaust fan but it's not vented, put a charcoal filter in it and use it - should still help a little.
Old 02-10-2020, 12:47 AM   #10
The firemen weren’t friends. I had electric work done (permitted) a few yrs ago. I was told code was I had to have a hardwired & battery SD. They went off Recently at 3:00 am waking me up, scaring me with the voice saying FIRE FIRE CARBON MONOXIDE CARBON MONOXIDE. I couldn’t tell which SD it was. They put one inside my bedroom and one outside. I had 4, they took different batteries which I didn’t have. Went to WM at 4:00 am. Bought batteries, had trouble holding flashlight while trying to get battery in. Got them to stop yelling.
My SD in past ALWAYS chirped a warning days before. These didn’t. Then I was afraid they’d go off again so I disconnected them. Of course I had 4 holes in the ceiling so I left them disconnected Without batteries but put them back up to cover the holes.
Then I went to the Fire Dept for answers. They said its a service to install them but they have to go on the ceiling. I didn’t get a close look at what they put up. At least the hardwire ones never went off when I cooked even when the kitchen had smoke.
I usually use my hood vent unless I’m fixing something quick. i’ve never had so much trouble with SD.
Ok, I’ll buy a photoelectric one.
Thank you
Old 02-10-2020, 01:19 AM   #11
Rewards Points: 712
keep in mind that if one of your hardwired alarms are interconnected, they all have to be compatible.
You can't just replace one and expect it to signal the other ones correctly.
Has to be same brand and other units listed to be compatible.
If you open the electrical box and all three wires from the female side of the wiring harness and connected to the electrical system, the alarms are interconnected.
Old 02-10-2020, 07:29 AM   #12
No I disconnected all the hard wired ones and removed batteries. I never want to use those again because they went off with no warning. At night.
Old 02-10-2020, 09:54 AM   #13
Rewards Points: 82
Surely the sensors are triggered through some motion around that causes false alarms. You should have found the cause instead of disconnecting them. Wired fire alarms are reliable ones.
coolair111 is offline   Reply With Quote
Old 02-10-2020, 11:12 AM   #14
Rewards Points: 712
In most areas, it's against the law to replace hard wired alarmed with 100% battery ones when they're required by code.
Rightfully so because you lose the interconnect feature and battery ones tend to be disabled when there's a low battery warning.
Old 02-11-2020, 09:25 AM   #15
raylo32's Avatar
Rewards Points: 1,246
How old is the problem SD? Old ones can get overly sensitive.
Live long and prosper.
raylo32 is offline   Reply With Quote
