Microwave Question - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Like Tree3Likes
  • 1 Post By huesmann
  • 1 Post By JIMMIEM
  • 1 Post By BayouRunner
Old 05-01-2020, 08:39 PM   #1
Microwave question
I have a 5 year old Sharp microwave and the turntable stopped spinning.. So i started to unscrewed the bottom screws.. While unscrewing I realised it actually has a easy access drawer but there were 4 screws in the middle which was holding something in place inside.. But now I am unable to find the part to screw it back.. Its hiding inside whatever it was.. I was wandering.. Can I start the microwave without finding what it these 4 screws were catching? Thanks
Maw_17 is offline   Reply With Quote
Old 05-01-2020, 08:42 PM   #2
These 4 holes were catching something from the inside which I cant find anymore..
Old 05-02-2020, 10:06 AM   #3
Rewards Points: 4,918
Re: Microwave question
So the thing is still inside?
huesmann is online now   Reply With Quote
Old 05-02-2020, 10:25 AM   #4
Yes! It is still inside.. But nothing is rattling inside as such..
Old 05-03-2020, 10:20 AM   #5
Then I would recommend opening the entire case.
Daneal likes this.
Old 07-19-2020, 06:51 AM   #6
Rewards Points: 52
Its seems new still now! Huesmann's suggestion appreciated
Daneal is offline   Reply With Quote
Old 07-19-2020, 09:10 AM   #7
Rewards Points: 868
Check the internet for maintenance instructions and diagrams for your product model. Microwave's can be very dangerous due to the high voltage capacitor. There isn't a lot of info about doing maintenance because of this, but info is available. It's a good idea to understand what you are dealing with before you venture inside.
Startingover likes this.
JIMMIEM is offline   Reply With Quote
Old 07-19-2020, 09:36 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,258
I guess I would not try operating it untill I knew it was safe.
Maybe have to get an actual appliance specialist on it......I don't think we have an actual specialist on here.
I generally will fix most appliances washer/dryer/DW/refrig/stove....but I'm chicken-chit to work on the micro.....too much electronic for me to understand and it involves some high charged capacitors and a magnetron.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-19-2020, 12:39 PM   #9
Rewards Points: 568
Microwave question
You took out the four screws that are holding the transformer in place. Yes it will operate. I wonít go as far as saying itís safe. Itís the heaviest part of the machine so I donít expect you would have any vibrations. Might be best to take it down and put them back
MTN REMODEL LLC likes this.
BayouRunner is offline   Reply With Quote
