Hawsco Eyewash Station - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 08-10-2019, 10:52 PM   #1
Rewards Points: 30
Hawsco Eyewash station
I tried adjusting the temperature by turning the mixing valve (both ways) with no result. Should I expect a temperature change right away or will it take a while?
Scm495 is offline   Reply With Quote
Old 08-11-2019, 06:38 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,498
Re: Hawsco Eyewash station
Does it rely on domestic water heating system, or is it self contained?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-11-2019, 02:50 PM   #3
Rewards Points: 3,142
Why would an eyewash station be plumbed to hot water?
LawnGuyLandSparky is online now   Reply With Quote
Old 08-11-2019, 03:45 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 662
If you are trying to raise the temp it will probably take a while as the water in the hot line is probably cold. If you are trying to cool it, then it should be instant- like a shower valve.
