Asbestos? - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Like Tree4Likes
  • 1 Post By Nealtw
  • 1 Post By Windows on Wash
  • 1 Post By AUAV8R
  • 1 Post By Yodaman
Old 01-19-2019, 11:55 AM   #1
Asbestos?
I am in the process of helping my girlfriend renovate her kitchen and I’m putting down vinyl flooring. The house was built in the early 70’s and has vinyl flooring already down. The corners are starting to come up so I pealed a little bit back. The photo is what was under the vinyl, could this possibly be asbestos?
AUAV8R is offline   Reply With Quote
Old 01-19-2019, 12:25 PM   #2
retired framer
Rewards Points: 16,998
Re: Asbestos?
Some did, there should be local lab that can test it for you.
Dave Sal likes this.
Nealtw is offline   Reply With Quote
Old 01-19-2019, 01:06 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 14,380
Re: Asbestos?
Could be. Most times, flooring wise, the asbestos is trapped pretty well inside the tile and substrate so that if you take it out normally and use care, you don't have much in the way of friability.
If you are concerned, get it tested.
Most asbestos floor tiles were 9" by 9". They were bad, but the mastic (most often black or brown) was.
Old 01-19-2019, 01:17 PM   #4
The flooring is actually vinyl sheet, not tiles. That makes me feel a little better about it. I was considering pulling it all up but after speaking to those who’ve done it, I’ll probably spend a little extra and just put down 1/8 inch underlayment.
Yodaman likes this.
Old 01-19-2019, 02:50 PM   #5
retired framer
Re: Asbestos?
Armstrong a few others had it in their paper.
Old 02-27-2019, 11:57 AM   #6
Rewards Points: 6
Re: Asbestos?
I would recommend to test it for lead paint as well!
Tomgirardi is offline   Reply With Quote
Old 06-21-2019, 04:13 PM   #7
Rewards Points: 260
Re: Asbestos?
lug-nuts is offline   Reply With Quote
Old 06-21-2019, 06:08 PM   #8
Property Mgt/Maint
Rewards Points: 8,206
Re: Asbestos?
Originally Posted by AUAV8R View Post
The flooring is actually vinyl sheet, not tiles. That makes me feel a little better about it. I was considering pulling it all up but after speaking to those whove done it, Ill probably spend a little extra and just put down 1/8 inch underlayment.
Laying down the underlayment is better approach anyway. If it is asbestos, it will be fine under the flooring. And the underlayment will give you a smooth surface to lay down the new vinyl.
And it's easier than stripping up old flooring.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 06-21-2019, 09:42 PM   #9
Rewards Points: 1,300
Re: Asbestos?
The preferred is 1/4 zero void AC plywood. Many installers wont go over 1/8 luan.
Armstrong is very specific about which grade of luan is acceptable, and the problems of using the wrong grade of luan. In any case, 1/4 material is the minimum acceptable to Armstrong.
https://www.armstrongflooring.com/co...erlayments.pdf
Anti-wingnut is offline   Reply With Quote
Old 06-22-2019, 06:28 AM   #10
Property Mgt/Maint
Re: Asbestos?
I just put down 200 feet of VCT using this product from Lowes https://www.lowes.com/pd/RevolutionP...4-X-8/50121135,
I was happy with it and will use it again. It suggest use is good for vinyl underlayment.
Ultimately, it is really up to the flooring MFG to determine weather a specific product meets their requirement. It is their warranty that most are concerned about.
I shoot them down with 1/4" narrow crown staples x 1 1/8 long. Spacing is 8x8 grid with every 4" around the perimeter. And then in high traffic areas I shoot an extra staple in the center of the grid squares.
New thread: Asbestos Vinyl floor tile demo question Sch84 Flooring 4 06-23-2017 07:28 PM
Asbestos resources Pt 1 RWolff How To Guides 11 08-01-2013 08:26 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-16-2010 11:28 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 10:49 AM
