Your Favorite Oil Semi Gloss? - Painting - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By mark sr
  • 1 Post By mark sr
  • 2 Post By woodco
Old 05-14-2019, 07:11 AM   #1
Rewards Points: 1,850
Your favorite oil semi gloss?
People,
Restoring a historic home, tons of woodwork. Best interior semi gloss oil paint?
It will be pure white, and I know it will yellow especially in darker rooms. But I hate latex finish and even how it is applied. Awful stuff. Spreading rubber on wood, to me.
I heard Behr alkyd and B Moore Regal (overpriced??)is good stuff.
Comments appreciated.
papereater is offline   Reply With Quote
Old 05-14-2019, 08:52 AM   #2
Rewards Points: 3,032
Re: Your favorite oil semi gloss?
Neither Behr Alkyd or Regal are oil based.
PPG probably has something good. Maybe Velour... Never tried it, as I stay away from oil, though.
Theres also oil base Pro-Classic. Cant go wrong there.
woodco is online now   Reply With Quote
Old 05-14-2019, 10:05 AM   #3
Hmm, without getting into organic chemistry, which I will gladly do if necessary, how do you define oil based? Alkyd is oil based for all intents/purposes. If an alkyd is not oil based what base is it?
Also, maybe I got the B Moore grade mistaken as Regal, whatever they carry will do. I must have confused the water based regal s gloss .
I will look into Pro Classic, if I can get it in my area. Thanks woodco.
Old 05-14-2019, 12:26 PM   #4
retired painter
Rewards Points: 1,416
Of all the oil base enamels that SWP sells, ProClassic is the interior oil base enamel that takes the longest to yellow. I pretty much quit using interior oil base enamel 20 yrs ago.
papereater likes this.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
papereater (05-14-2019)
Old 05-14-2019, 05:05 PM   #5
Now thats good to know! Thanks, mark!
Old 05-14-2019, 05:31 PM   #6
Rewards Points: 1,718
Advance or Cabinetcoat
cocomonkeynuts is offline   Reply With Quote
The Following User Says Thank You to cocomonkeynuts For This Useful Post:
Old 05-14-2019, 05:50 PM   #7
alkyd refers to the resin (opposed to acrylic for example), there are soya, linseed, synthetic alkyds. The carrying vehicle can be water or an oil.
Advance for example is a waterborne alkyd. Many traits of traditional oil paints but soap and water cleanup. one of the best trim paints you can use.
Old 05-14-2019, 05:59 PM   #8
Oil based is if the paint resin is in an oil, and you use mineral spirits to clean your tools.
Alkyd is a paint resin, which used to be available only in an oil base, but nowadays they have hybrids, which have alkyd resin, with water to thin and clean. They dont look quite as good as a real oil base, because they need to be applied very thin, and oil base, can be put on a little heavier. If you are a stickler on the "true" oil base look, hybrids dont quite get there, but they are very close. From more than a foot away, you cant tell the difference. If the surface is perfect, a hybrid will look as good as an oil.
Some hybrids (not technically all hybrids, but waterborne alkyds, nonetheless) include pro classic hybrid, advance, behr alkyd, etc. I wouldnt consider cabinet coat a hybrid. I think its in another category. Hell, Scuff-x looks damn close to an oil too.
If you want behr oil base, get the can that says Behr Oil Base. Its different. I've used Behr Alkyd, its actually a decent product, but its waterborne. YOu have to put it on really thin, and it doesnt like humidity at all. Personally, I hate oil base, so I get waterborne products that get close to the look.
A question for Coco: Is there a semi-gloss equivalent to satin impervo? Tahts the best oil out there, but its not semi gloss...
The Following User Says Thank You to woodco For This Useful Post:
Old 05-14-2019, 06:24 PM   #9
Wow, good to know. But cant you clean a brush in alkyd with Min spirits?
So, youre saying, "oil base" is the more older/traditional stuff, and alkyd is not? I like paint that levels out beautifully (oil) AND covers well, not like rubberized latex that leaves streaks and does not cover worth of beans. . I used to get that decades ago when I painted professionally.......not sure these days what formulas theyre using.....
Sounds more like I need to chase down "oil base"
Thanks.
Old 05-14-2019, 08:47 PM   #10
Used to be dualmel that was a good product.
Current semigloss oil enamels:
P24 D.T.M. ALKYD SEMI-GLOSS
Superspec ALKYD SEMI-GLOSS
Rustscat POLYURETHANE INT/EXT ENAMEL
(most durable)
papereater (05-15-2019)
Old 05-15-2019, 05:37 AM   #11
retired painter
You are describing the cheaper latex enamels. The quality latex enamels have come a long ways over the last 20-30 yrs. Some alkyds are oil base but some are waterborne. What Woodco said,
Old 05-15-2019, 03:03 PM   #12
Thanks, Mark for clarifying. If you say real oil base looks better, thats all I need to know.
I hope I didnt nudge you to admit that. Yes, I am kind of a stickler of the oil look. Isnt anybody else?
Old 05-15-2019, 03:43 PM   #13
retired painter
Real oil base enamel looks better until whites or light colors start to yellow. I switched to waterborne enamel a long time ago and never looked back.
papereater (05-18-2019)
Old 05-15-2019, 05:22 PM   #14
Real oil looks a little better, until it ages. I also hate the way oil cracks over time cuz its so brittle.
You'd be amazed at how far waterborne paints have come though. Some waterbornes look damn close. Also, they dont make oil as good as they used to either... Its had its VOC's lowered, so it doesnt perform the same.
papereater and mark sr like this.
Old 05-18-2019, 09:53 PM   #15
good to know. thanks. I learned a bunch.
need advice on semi gloss Donna17 Painting 3 07-09-2014 10:30 AM
Semi Gloss in White and Spackle Spots have NO Gloss - What's happening here? 777funk Painting 41 08-19-2013 10:36 PM
semi gloss not covering laura1 Painting 9 03-07-2011 11:41 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
