What's Going On.....????? - Painting - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 06-08-2016, 06:26 PM   #1
Rewards Points: 1,280
What's going on.....?????
I'm painting my powder room upstairs....ceiling and walls
I'm having problems with the ceiling, to the point I had to use a drywall knife to remove it before it dries up !!!
This is how it looked like (picture below):
The ceiling was already painted (not brand new drywall)
Yesterday, I sanded it and applied a skimcoat of "Dust Control" joint compound from Home Depot
Tonight (so 24 hours later), I sanded it real smooth, and it looked great. I used a slightly damp sponge to remove the dust
I purchased the Sherwin Williams Ovation special ceiling from Lowes....
Then I started to paint and got what you see on the picture: awful texture !!!
I'm not a pro, but I've painted several walls and ceiling in the past, without having any issue like that. Last december, I painted the downstairs powder room (wall, ceiling and trim) and was really happy how it turned out. Last summer, I painted my daughter's bedroom (walls only) and had great results
Looking at the picture, what do you think happened???
Is it because of the paint itself, the joint compound skimcoat?
Should I have used a primer first?
I'm planning to sand again tomorrow night, and paint with another brand. But now I'm scared to have the same issue !!!!
I need your help...............
french_guy is offline   Reply With Quote
Old 06-08-2016, 07:08 PM   #2
Rewards Points: 3,125
Re: What's going on.....?????
Probably the paint itself. Maybe it froze or went bad or just defective.
Possibly lack of stirring or completely the wrong roller cover. But I'm blaming the paint.
mathmonger is offline   Reply With Quote
Old 06-08-2016, 07:18 PM   #3
Lord of Slums
Rewards Points: 1,974
I am thinking the paint as well. Could of been some sort of contamination on the surface.
mj12 is offline   Reply With Quote
Old 06-08-2016, 07:28 PM   #4
I haven't asked the store to shake the can (1 qt) but I think I stirred it properly
But when I was doing my cut in, I found the paint to be pretty liquid/runny, not covering that well and drying very fast
My skimcoat was real smooth, so I thought I could use a 1/4" nap roller. When I saw how it looked like, i switched to a 3/8" nap....same thing
Do you think I should have primed before, or going directly with paint is OK (I was planning to put 2 coats anyway)?
Which paint would you recommend, and which roller?
I guess my next step for tomorrow night is to re-sand everything....and paint again!!!
Old 06-08-2016, 07:33 PM   #5
Rewards Points: 9,826
Yes, you should have primed first. But I don't know if that was the issue. Something strange going on --- it looks glossy --- ceiling paint is normally flat.
SPS-1 is offline   Reply With Quote
Old 06-08-2016, 07:37 PM   #6
This is the paint I purchased:
http://www.lowes.com/pd/HGTV-HOME-by...fl-oz/50404096
So for tomorrow, after sanding: should I prime (and in that case which one would you recommend) or can I go right away with paint (another one of course.....and which one should I get)?
Old 06-08-2016, 07:56 PM   #7
Might want to wait a while before sanding -- its likely to gum up your sandpaper with how fresh it is. Link wasn't working, but I googled it -- says 3/8-3/4" nap roller ????? -- 3/4" -- wild -- I think you had it right initially with the 1/4" roller. Better wait for a pro to chime in --- something strange here that I don't understand.
Old 06-08-2016, 08:02 PM   #8
Before I purchased the joint compound (Dust Control), I read the reviews and many were saying it was taking forever to dry....!
But I only applied a very thin skimcoat, and when I sanded it 24 hours later (tonight), it seemed pretty hard to me.....
I'm really pissed because the surface after sanding was real nice....!!!!
Old 06-08-2016, 08:11 PM   #9
Super Moderator
Gymschu's Avatar
Rewards Points: 378
You will not be able to sand that flat. You will be skim coating again, unfortunately.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 06-08-2016, 08:16 PM   #10
I've removed it.......when I saw how bad it was looking, i knew there was something wrong somewhere.
I thought for a fraction of a second I should leave it like that and maybe it will flatten when drying, but then I decided it was safer to remove it (with a 6" drywall knife) when it was still fresh....I'm glad I did
So now I'm back with my 1st skimcoat (few spots with a very thin layer of paint that I should be able to sand)
Gymschu likes this.
Old 06-08-2016, 08:58 PM   #11
Rewards Points: 1,816
Any idea how old the prior paint is?. At one point about ten years back doing a ceiling that was ten years older than that, the latex paint reacted with I what was there and did what you ran into. A scraping and hitting it with an oil based primer sorted things out. Ron
ront02769 is offline   Reply With Quote
Old 06-09-2016, 01:48 AM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 2
What kind of paint was on the ceiling originally? Maybe oil?
Old 06-09-2016, 05:48 AM   #13
I don't know what paint was on the ceiling originally
But I would think it was the same paint everywhere, and I had no issue for the powder room downstairs (ceiling and walls), my daughter's bedroom (walls), my daughter's bathroom (celiling and walls), dining room and living room (walls)
The only thing I've done differently this time was to completely skimcoat the ceiling and use this paint for the 1st time (other rooms where Behr and Benjamin Moore)
When I sanded it (24 hours after skimcoating)), it sanded very well and final result was smooth. It looked completely dry (visually and by touching it)
I'm going to resand and paint tonight:
-) Should I prime, and then which primer should I use with which roller?
-) Can I paint directly (no primer)? Which paint would you recommend? I'm planning to stick with a 1/4" nap roller.......unless you tell me otherwise
My ceiling is approximately 15 sq ft
Old 06-09-2016, 06:31 AM   #14
Rewards Points: 1,944
What was the name of that old farmers dog again? Oh yeah-BINGO!
A ceiling paint that says it is scrubbable? Really? Why?
Gymschu likes this.
klaatu is offline   Reply With Quote
Old 06-09-2016, 06:32 AM   #15
Rewards Points: 6,236
Sounds like the mud was not totally dry then the moisture in the paint softened it up more. Then since a 1/4" nap roller holds almost no paint the tendency is to push harder. It left that pattern in the wet mud. And yes you should have primed.
Entering your general location can help with answering a lot of times
