Using Melamine Paint On New Oak Floor Risers - Painting - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 07-09-2019, 08:23 AM   #1
Rewards Points: 16
Using Melamine paint on new oak Floor risers
I am thinking of priming the stairs with an Oil based primer and then sponge rolling on two coats of white melamine paint.
Is this the best way to do it? Should I be using Melamine paint?
rpciam is offline   Reply With Quote
Old 07-09-2019, 10:17 AM   #2
Rewards Points: 2,236
Re: Using Melamine paint on new oak Floor risers
Use a porch and floor enamel...
cocomonkeynuts is online now   Reply With Quote
Old 07-09-2019, 10:40 AM   #3
retired painter
Rewards Points: 506
I agree with P&D enamel but disagree with painting the treads white as you'll never keep them clean and paint will show wear quicker than poly will.
mark sr is offline   Reply With Quote
Old 07-09-2019, 11:04 AM   #4
Rewards Points: 16
Sorry, I am just referring to the risers (not the treads). The treads I have Floor grade Varathane.
The Risers, I am thinking Oil based primer and then foam rolling on two coats of white melamine paint.
Is Melamine paint the right way to go or would it chip?
Old 07-09-2019, 11:06 AM   #5
retired painter
Rewards Points: 506
I assume they currently have poly. I'd sand lightly and apply a coat of solvent base primer, sand lightly when dry and apply 2 coats of your choice of enamel. Most any decent enamel will adhere and preform well over the primer. I'd likely use SWP's ProClassic waterborne enamel.
Old 07-09-2019, 11:21 AM   #6
Rewards Points: 16
No poly, as the title states "Using Melamine paint on new oak Floor risers".
I have bought Melamine which says "Waterborne acrylic enamel" on the label.
I guess I am good then
Thanks for your help
Old 07-09-2019, 11:27 AM   #7
retired painter
Rewards Points: 506
Sorry, I misunderstood. If they haven't been installed yet you can save a lot of time priming and applying the first coat of enamel prior to installation.
Old 07-09-2019, 11:36 AM   #8
Rewards Points: 16
Ah, yes I will do that.
Thanks again
Old 07-09-2019, 12:36 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,308
RPCIAM......
I agree with the above posts...and I guess with your acrylic enamel..... but I've never seen a "Melamine" paint enamel....who makes it...is it any different than any acrylic enamel.....like what does it cost...(somewhat an indication of quality...)
TIA for my education....
MTN REMODEL LLC is online now   Reply With Quote
Old 07-09-2019, 12:45 PM   #10
Rewards Points: 1,926
You could also use thin melamine boards for the risers. Cut them clean and glue them in place.
Or, you could white tile on the risers. Just butt them together and use mastic. No need for grout.
I am planning on painting my risers and then stenciling the names of our favorite ski areas on them. Gotta find someone who has a crickut printer and vinyl to print on.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 07-09-2019, 01:09 PM   #11
Rewards Points: 16
hmm, I bought this stuff but after reading the reviews online, I am rethinking it:
https://www.canadiantire.ca/en/pdp/p...-0488642p.html
It sounds like Rustoleum makes it also.
Old 07-09-2019, 01:15 PM   #12
retired painter
Rewards Points: 506
I've never heard of that paint but the odds are it will be ok. Other than toe kicking smudges it's not like the risers are subject to wear. I've always found it easier to touch up the risers than try to clean off the smudges.
Old 07-09-2019, 01:33 PM   #13
Rewards Points: 16
Yes, good point.
Old 07-09-2019, 01:40 PM   #14
Another possibility is using white board material or white board paint. Ben Moore makes some and I am sure there are others.
Or just paint it in Satin or Semi-Gloss 100% Acrylic paint or Acrylic/Alkyd paint. Or if you don't mind cleaning up with mineral spirites, 100% Alkyd paint.
Old 07-09-2019, 02:25 PM   #15
retired painter
Rewards Points: 506
While I've painted countless risers with oil base enamel it's not something I would recommend. Oil base whites will yellow and while it is more scrubable than latex or waterborne enamel it's a lot harder to touch up.
