DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Painting (https://www.diychatroom.com/f4/)
-   -   Stomp texture on old plaster ceiling? (https://www.diychatroom.com/f4/stomp-texture-old-plaster-ceiling-65004/)
flatlander745 02-21-2010 01:12 PM
I have a very old apartment building that sat vacant without heat for 5 years and all the paint is popped and peeling from the ceilings and walls; I need to get them painted again. I started scraping the ceiling and alot of it comes off with medium effort, then there are areas that do not budge. I am wondering if I can stomp right over this(after I scrape all that will come loose), or if i hit it with a primer coat will it hold up and not pop further to just be painted? The plaster is very smooth and hard, like the smooth side of durock with a yellowed color to it.
Thanks!!
NAV 02-23-2010 02:03 PM
Yep, scrape off the loose, prime with a solvent based primer and then you have a couple options.
  1. just paint it and have it look like crap
  2. Skim coat it so it is smooth
  3. skim coat and texture - if you do not feather the transition from the peeling paint to the bare substrate you may see the transition through the texture.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
