Should I Install The Spigot Before Or After The Spray Foam Insulation? - Painting - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Marky82
Old 09-12-2017, 08:44 AM   #1
Rewards Points: 4
Should I install the spigot before or after the spray foam insulation?
My Sand cellar is being coated with foam. A spigot will be installed that will run through the cellar to the outside. Do I want a tight foam seam around that pipe (or pex, I'm not sure what's being used for it) or should I foam first then drill a tiny hole through the foam to install the spigot after - making it easier to access later if need be?
rocktop is offline   Reply With Quote
Old 09-12-2017, 10:08 AM   #2
Rewards Points: 266
Re: Should I install the spigot before or after the spray foam insulation?
I would install the spigot first, you want to keep everything air sealed which foam does very well. You can always trim the foam later if you need to fix something.
47_47 and mark sr like this.
Marky82 is offline   Reply With Quote
Advice for Spray Foam Insulation on Liquid Rubber coated walls Kenora_Reefer Insulation 2 09-09-2015 08:09 PM
Radiant barrier WITH spray foam insulation Darmatran Insulation 4 09-08-2014 06:22 PM
Foam insulation on foundation arisley28 Concrete, Stone & Masonry 0 07-30-2013 01:03 PM
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 11:53 AM
yellow spray foam insulation bee Insulation 1 03-12-2011 01:48 PM
