Sealing/priming MDF/birch Plywood Combo - Painting - DIY Chatroom Home Improvement Forum
Old 02-13-2020, 08:37 PM   #1
Rewards Points: 18
Sealing/priming MDF/birch plywood combo
I have new speaker cabinets made out of Baltic Birch plywood but the front baffle is MDF. So the MDF ends have to be sealed.
Initially I was planning on spraying Mohawk E-Z Vinyl Sealer M102-8000 on the MDF because it has been recommended in a few YouTube videos. I got 2 cans of the stuff which will not be enough to spray the speakers all over. So I was going to use Zinsser BIN on the birch plywood and overlap the vinyl sealer and BIN. Is the BIN going to adhere to the vinyl sealer if I do this or should I simply use only BIN on both the MDF and plywood parts?
The joints between MDF and plywood are smooth and where there is a small gap it is filled with Titebond glue and sanded.
They will then be spray coated with satin black Sherwin-Williams Emerald Urethane.
tapio is offline   Reply With Quote
Old 02-14-2020, 06:50 AM   #2
retired painter
Rewards Points: 1,868
Re: Sealing/priming MDF/birch plywood combo
BIN adheres to most anything although you should scuff sand the other sealer first.
mark sr is offline   Reply With Quote
