Screwed On New Corner Bead - Painting - DIY Chatroom Home Improvement Forum
Old 08-19-2016, 08:29 PM   #1
Rewards Points: 344
Screwed on new corner bead
Had my roof replaced a few weeks ago and they used a dark brown metal nosing on all the edges. I painted it using an exterior semi gloss latex paint. The brown is showing through the paint after two full coats. Any thoughts on how I could fix this would be much appreciated. Thanks
drew53813 is offline   Reply With Quote
Old 08-19-2016, 08:35 PM   #2
Rewards Points: 144
Re: Screwed on new corner bead
Don't know why you would want to paint new drip edge.It is anodized aluminum and hold up for years.
mako1 is offline   Reply With Quote
Old 08-20-2016, 11:56 AM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 6,770
Yes, rather odd to paint it white as it will show all the dirt from water running off the roof.
White paint with today's formulas doesn't cover well at all. It's not unusual for you to need 3 or 4 coats to cover, especially a dark color. You're just going to have to bite the bullet and apply another coat or two.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
oh'mike (08-20-2016)
Old 08-30-2016, 02:01 PM   #4
Rewards Points: 14
exactly!
mmelton005 is offline   Reply With Quote
Old 08-30-2016, 02:06 PM   #5
Rewards Points: 14
exactly!
Old 08-30-2016, 08:26 PM   #6
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 1,138
I always get my white paints tinted white, which seems to help with the coverage of white paint.
-Paul
Checkout my YouTube Channel with 61,000 Subscribers and over 10,000,000 Views
https://www.youtube.com/paulpeck
Sir MixAlot is offline   Reply With Quote
Corner bead options Dorado Drywall & Plaster 6 06-01-2013 02:22 PM
repairing long crack along metal corner bead joetab24 Drywall & Plaster 15 06-26-2012 03:29 PM
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 09:53 PM
Corner Bead Repair? How? kennykenny Painting 5 01-25-2012 06:55 PM
Ceiling corner bead kchopper Drywall & Plaster 8 03-18-2010 10:36 AM
