Is This Safe? - Using This Primer Inside Garage - Painting - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 09-11-2019, 12:32 AM   #1
Rewards Points: 474
Question
is this safe? - using this primer inside garage
going to use this to spot prime: BM Alkyd Primer, 024 - oil based in the garage on about a dozen boards set up on sawhorses just a few feet from the hot water tank - which is gas and has a pilot. The tech sheet says:
"Keep away from heat and flame. Use only with adequate ventilation."
There is an exhaust fan above the wood venting outside. Behind me is a window and there be a couple of fans blowing in and at the other end of the garage the door will be and i'll have a couple of fans blowing out.
i do have a really good respirator that i'll be using, i just don't want the fumes to be set off by the pilot. I don't think they will - but you all have way more experience with this than i do.
Is this safe to do?
Thanks,
Jim
UltraRed is offline   Reply With Quote
Old 09-11-2019, 03:23 AM   #2
Rewards Points: 4,170
Re: is this safe? - using this primer inside garage
Applying by brush would likely be ok. Don't know that I'd want to be spraying it.
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
UltraRed (09-11-2019)
Old 09-11-2019, 04:30 AM   #3
retired painter
Rewards Points: 1,736
If you want to spray it isn't a big deal to cut the gas off until you are done. The odds are the fumes and pilot flame won't be an issue but it's better to play it safe.
huesmann likes this.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Old 09-11-2019, 11:14 AM   #4
Rewards Points: 474
will be using a paint brush....
Old 09-11-2019, 11:24 AM   #5
retired painter
As SS stated, brushing will be fine - no issue with the pilot light.
