Re-staining Deck Prep Questions - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 08-21-2019, 11:35 AM   #16
Rewards Points: 1,392
Re: Re-staining deck prep questions
Originally Posted by tmittelstaedt View Post
I simply cannot use any kind of stripping that has a strong mechanical component such as heavy brushing or any of that. I'll end up with terribly furry wood that has gouges in it. I have to use a chemical stripper that can dissolve and lift away the old stain with minimal mechanical action. If it can also dissolve and lift away the bleached spring and summer wood that's great. But I can't do much more than hose it off with a little gentle agitation.
Maybe as klaatu said I should just give up the idea of a stripper and sand it instead.
Or you know a product that is designed for that purpose like BM Restore...
cocomonkeynuts is offline   Reply With Quote
Old 08-21-2019, 03:31 PM   #17
Rewards Points: 4,378
ron45 is offline   Reply With Quote
Old 08-21-2019, 05:33 PM   #18
Originally Posted by ron45 View Post
You can safely ignore anyone who recommends thompsons waterseal
mark sr likes this.
Old 08-22-2019, 05:43 AM   #19
1) It's not a cedar deck in the video
2) I already said power washing was off the table
3) I already said I bought 8 gallons of deck stain. T.W.S. is not intended to be used before stain.
Basically you didn't read any of the thread. Is Amway selling this stuff nowadays?
tmittelstaedt is offline   Reply With Quote
Old 08-22-2019, 06:36 AM   #20
ZTMAN's Avatar
Rewards Points: 336
I am probably in the majority of homeowners that stain a deck the wrong way, but I liked the results.
Moved into a house that had a rather large mahogany deck that the prior own applied a solid burgundy stain. (idiot)
Stain mostly wore off, but after I got it to a point I was satisfied, I put a semi transparent stain in a pumper (with spray tip off) laid down lines of stain and spread with a stain pad. Had a brush in the back pocket if a joint needed hit.
Had two big dogs that were hard on the deck so I did this once a year. With two people, one on the pump, one on the pad, took about 1 hour. Did the rails about every five years.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
