Painting New Blue-board W/veneer Plaster & Slanted Ceiling Questions - Painting - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 2 Post By ClarenceBauer
  • 4 Post By Gymschu
  • 1 Post By gratefulgardenr
  • 1 Post By ClarenceBauer
  • 1 Post By chrisn
Old 09-22-2018, 02:52 PM   #1
Rewards Points: 20
Painting new blue-board w/veneer plaster & slanted ceiling questions
Hi friends
We're painting over cured veneer plaster and have been getting a lot of conflicting advice. The plasterer says just use any paint w/primer in one and it'll be fine as long as we wait 2 weeks for the plaster to cure. The paint store says you MUST use an acrylic, alkaline resistant primer first. We're fine with primer first, but interested in getting some more advice. We're also not sure of paint brand and type. We're looking at Sherwin Williams and Benjamin Moore primarily. Are there any particular brands and types you recommend?
Also, this is a small apartment with slanted ceilings that have skylights. The plaster is flat on the walls but swirled on the slants and ceilings. We'd like to paint one color for the walls and ceilings, but I'm not sure how to manage the finishes. Most contractors and DIYers I've read recommend flat paint for ceilings and a matte or eggshell for walls. But do I paint the slanted parts with the wall or ceiling sheen? Or since it's small and all one color, do I just paint one sheen everywhere?
Thanks for your advice!
gratefulgardenr is offline   Reply With Quote
Old 09-22-2018, 03:28 PM   #2
Rewards Points: 4,536
Re: Painting new blue-board w/veneer plaster & slanted ceiling questions
That would be the last question I'd ever ask him about painting....
You went to an actual paint store for advice - good for you. I would follow their advice on the primer. Personally, I like satin type finishes, which is typically a little more sheen than eggshell but eggshell is perfectly fine for walls. As to the slanted portion, if you plan to make them the same color as the walls, I would match the sheen. If white, then I would use a flat paint like a ceiling. Another color than the walls but not white and I'd want more details like the actual colors and maybe some pictures of the space.
stick\shift is offline   Reply With Quote
Old 09-22-2018, 03:45 PM   #3
Rewards Points: 386
Painting of Veneer Plaster as per U.S.G. page # 230 of the hand book states Make sure plaster is dry plaster may be dry in as little as 24 hours.
Use a high - quality, undiluted acrylic latex, vinyl or alkali - resistant alkyd paint. For epoxy - based finish system , the veneer plaster must be properly sealed. Quick - drying vinyl acrylic latex or alkali - resistant alkyd primer - sealer are recommended. Polyvinyl acetate PVA based primers should not be used. Note I have been plastering for over 40 years and the USG plaster will be dry after the 24 hour period when applied over the USG Blue Board
( Imperiod Plaster Board )
Gymschu and SeniorSitizen like this.
ClarenceBauer is online now   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
gratefulgardenr (09-22-2018)
Old 09-22-2018, 03:57 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 336
@ClarenceBauer , I'm always glad you're on board to answer these plaster related questions!
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 09-22-2018, 05:49 PM   #5
Rewards Points: 20
Thank you! Here are some photos. I am looking at Sherwin Williams colors: sage, softened green, koi pond, and colonial revival green. I decided to paint the same color walls and ceilings after reading a post about slanted ceilings on the decorologist dot com. I'd love to hear what you think! Thanks again!
Painting new blue-board w/veneer plaster & slanted ceiling questions-img_6207.jpg   Painting new blue-board w/veneer plaster & slanted ceiling questions-img_6208.jpg   Painting new blue-board w/veneer plaster & slanted ceiling questions-img_6212.jpg   Painting new blue-board w/veneer plaster & slanted ceiling questions-img_6214.jpg
Old 09-22-2018, 05:54 PM   #6
Rewards Points: 20
Thank you, Clarence! I'll use the acrylic primer from Sherwin Williams: Loxon blue label. There was also a Benjamin Moore recommended: UltraSpec Masonry (100% acrylic). Any opinions about those? And once it's primed, any type of quality paint over it, right? Nothing special? Thanks again!
Old 09-22-2018, 05:54 PM   #7
Super Moderator
Gymschu's Avatar
Rewards Points: 336
Count me as one of those that absolutely dislikes when the ceilings and walls are painted the same color. To me it makes a room look "boxy" and can be so dark that it is cave-like. I would paint anything that is textured the ceiling color and the smooth, flat walls the color you pick out. You don't necessarily have to have bright white on the ceiling. It could actually be the lightest color of green on the color swatch where you choose the wall color. Just my two cents.
The Following User Says Thank You to Gymschu For This Useful Post:
chrisn (09-23-2018)
Old 09-22-2018, 06:07 PM   #8
Rewards Points: 20
Thanks! I know what you mean about the cave. But we have rooms in our house that we painted the ceilings white and the walls (including the slant) the wall color, and at least that doesn't make us feel like the ceiling is coming down on us. Really, with the slants the wall color, it makes the room feel higher. But still, with all the angles, the room is choppy looking. I don't know if you went to that decorologist dot com (I can't post the link), but if not, type that in and search slanted ceilings. The photos on that page made me want to paint the ceilings the wall color. Let me know what you think. Thanks again!
Gymschu likes this.
Old 09-22-2018, 06:45 PM   #9
Rewards Points: 386
I don't do painting only trade I am in is plaster / Stucco
gratefulgardenr likes this.
Old 09-23-2018, 05:15 AM   #10
retired painter
Rewards Points: 224
I also prefer white ceilings. With that texture I wouldn't be afraid of satin/eggshell on both the walls and ceilings. Unlike a slick finish ceiling any discrepancies in the finish will for the most part be hid by the texture.
mark sr is offline   Reply With Quote
Old 09-23-2018, 07:53 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 2
Thanks for saving me the time to type the same thing!
Gymschu likes this.
Tags
paint brands , plaster veneer , primer necessary , sheen , slanted ceiling
What primer to use on veneer plaster over blue board? beand1p Painting 1 08-27-2018 02:34 PM
What primer to use on veneer plaster over blue board? beand1p Drywall & Plaster 1 08-27-2018 02:26 PM
Plaster ceiling Q w photos alishag Drywall & Plaster 0 03-30-2017 07:46 AM
Vapor on slanted bath ceiling with tile & skylight mkjeld Building & Construction 2 04-20-2011 12:26 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
