Painting Exterior Door With Weather Stripping. - Painting - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 01-14-2020, 10:56 PM   #1
Rewards Points: 1,100
Painting exterior door with weather stripping.
In another thread I took a new primed exterior door and painted it and had a problem with paint drying too fast. Simple job was a pain.
This door is an exterior door in the garage into the house, with weather stripping. I searched the net for paint sticking to weather stripping and see answers all over the place. Don't let weather stripping touch paint for 24 hours up to 10 days, replace weather stripping with silicone weather stripping, masking tape weather stripping. What to do?
This is Sherwin Williams interior Super paint in a satin finish.
jjrbus is offline   Reply With Quote
Old 01-15-2020, 12:27 AM   #2
Rewards Points: 972
Re: Painting exterior door with weather stripping.
I would use oil based paint, which will harden and not be sticky. Latex paint contains plasticizers and will tend to get soft and sticky in hot weather, which FL has plenty of. Whatever you do the door has to come off or remain ajar till the paint dries.
jjrbus likes this.
Old Thomas is offline   Reply With Quote
Old 01-15-2020, 02:17 AM   #3
retired framer
Rewards Points: 5,972
Type of weatherstripping, if it is the type that slides in the slot it is removable.
jjrbus and Gymschu like this.
Do not use flat bottom gables with scissor trusses.
Old 01-15-2020, 06:24 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 1,258
I agree with Neal. Rubber/plastic weather stripping should be removed prior to painting. Nothing sloppier than paint spread over the stripping.
SPS-1 and jjrbus like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-15-2020, 06:29 AM   #5
retired painter
Rewards Points: 1,754
I can't remember the last time I painted a new exterior door that didn't have removable weatherstripping. I like to remove the weatherstripping and reinstall it a few days later after the paint has had enough time to dry.
Many steel door manufactures state that using an oil base paint will void the warranty. The main reason is because the metal is thin and if it expands/contracts with temp changes oil base coatings can crack/peel and take the factory primer with it. Latex paints will flex just enough to prevent that issue.
jjrbus likes this.
mark sr is online now   Reply With Quote
Old 01-15-2020, 07:37 AM   #6
Rewards Points: 3,078
i say skip the oil base. Pull the stripping, reinstall in a day or two.
jjrbus likes this.
woodco is offline   Reply With Quote
Old 01-15-2020, 07:39 AM   #7
Thanks for the responses, I should have mentioned I removed the door and laid it flat to paint. Nothing screams crap job more than paint all over weather stripping!
Now that I think about it some of the shelves I have painted with latex paint stayed sticky for a long time!
I have a set of metal swinging patio doors to do also, just the inside. What do you think of having a can of automotive type spray paint made? I have heard of it but know nothing about it.
Old 01-15-2020, 08:04 AM   #8
retired painter
Sounds like you need a better quality latex paint. Many of the cheaper latex enamels never dry to a hard film and blocking [sticky] is a problem. A quality latex enamel won't have that problem.
jjrbus likes this.
Old 01-15-2020, 08:31 AM   #9
Sherwin Williams interior Super Paint in a satin finish. This is in the garage with constant high humidity and temp.
Old 01-15-2020, 08:50 AM   #10
retired painter
While I've used a good bit of SuperPaint interior satin I've never used it on doors/trim. I normally use their ProClassic waterborne enamel.
jjrbus likes this.
Old 01-15-2020, 05:47 PM   #11
Super Moderator
Gymschu's Avatar
Rewards Points: 308
All-Surface Enamel or Snap Dry would have been better choices than SP, although, really, SP should have been fine. A trick to keep the weather stripping from sticking to your newly painted door is to coat the weather stripping with a thin layer of WD-40. I often have to do this because homeowners want to be able to close their doors before nightfall.
jjrbus likes this.
"In the heat of battle, my father wove a tapestry of obscenity........."
Gymschu is online now   Reply With Quote
Old 01-15-2020, 05:50 PM   #12
Rewards Points: 28
do NOT use oil based paint (t becomes brittle as it ages, and has poor color retention). It is considered inferior to 100% Acrylic Exterior Paint.
I like SW Emerald Urethane for doors (which can actually be used for interior and exterior side of door).
jjrbus and mark sr like this.
CB750 is offline   Reply With Quote
Old 01-15-2020, 06:33 PM   #13
I have been scouring the net and one suggestion is using painters tape on weather stripping.. Since this door is inside the garage I have the option of leaving it off for a few days. I sealed the doorway with plastic, inconvenient going around but better than the paint peeling off door.
Gymschu likes this.
Old 01-15-2020, 07:52 PM   #14
Why dont you put the door on, but just leave the weather stripping out for a couple days? I dont understand.
Even at clients houses, when I paint their door, I finish the job and tell them to put it in themselves in a couple days, if Im gonna be gone.
mark sr likes this.
Old 01-15-2020, 08:12 PM   #15
Well duh, why didn't I think of that?
