Painting Door Frames - Painting - DIY Chatroom Home Improvement Forum
Old 02-29-2016, 12:38 PM   #1
Rewards Points: 2
We live in a house that was built in the mid-70s. I believe it is a pre-fab. It has cheap doors and the door cases are wood with it looks like some kind of vinyl covering over it to match the doors. Unfortunately, we just can't afford all new doors so I'm wondering if I can paint the door frames and doors.
Any ideas as to what kind of primer and/or paint?
paint helper is offline   Reply With Quote
Old 02-29-2016, 03:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,814
If it is vinyl, there are very specific prep and primers for that type of substrate.
A good paint supply store should have everything that you need as well as the proper advice.
Old 02-29-2016, 04:36 PM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 258
Zinsser 1-2-3 latex primer, it's cheap and sticks to anything, even glass. Then, 2 topcoats in your favorite paint, usually semi-gloss for doors and trim.
"In the heat of battle, my father wove a tapestry of obscenity........."
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
SeniorSitizen (03-04-2016)
Old 03-01-2016, 02:17 PM   #4
Rewards Points: 6,236
Would like to see a pic if you can send one.
Entering your general location can help with answering a lot of times
The Following User Says Thank You to ToolSeeker For This Useful Post:
slinger58 (03-01-2016)
Old 03-01-2016, 06:35 PM   #5
Old Paint Contractor
Rewards Points: 104
I'd like to see a pic, too. Never heard of a vinyl clad door casing.
slinger58 is online now   Reply With Quote
The Following 2 Users Say Thank You to slinger58 For This Useful Post:
chrisn (03-02-2016), ToolSeeker (03-02-2016)
Old 03-03-2016, 11:58 PM   #6
Painting contractor
Rewards Points: 341
You must have never seen the trim in mobile homes. It's like a veneer over particle board.
Red Dog is offline   Reply With Quote
The Following User Says Thank You to Red Dog For This Useful Post:
Gymschu (03-04-2016)
Painting Tips on Painting Furniture alexdavid Painting 0 11-13-2014 04:45 AM
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
New Member: Painting Contractor Induspray New Member Introductions 3 01-04-2010 08:50 PM
